REAL MILK PAINT
Wiring Help Needed
Wiring Help Needed
Wiring Help Needed
William Duffield
I'm designing and building an oracle, which is basically a revolving book/magazine/DVD shelf, with an independently revolving book/music stand on top. Here is a simplified example.
For the upper stand, start with something like the Jefferson music stand. Another simplified example.
I would like to wire some electrical outlets into both revolving cases, so I could use them for charging phones, etc., perhaps put a printer on top, and connect a reading lamp, etc. Both cabinets will be supported by metal lazy susans, like these from Woodcraft, so there will be plenty of room up the center for whatever I will need to transfer power.
http://www.woodcraft.com/Product/2001061/573/Triangle-Mfg-Flat-Round-Lazy-Susan-12-516-Thick-Capacity-1000-lbs.aspx
Has anyone here done something like this? Is there a commercially available power transfer mechanism that I can purchase and install? Alternately, does anyone have plans for one I can build?
I would prefer manufactured, with UL approval, for obvious reasons.
Re: Wiring Help Needed
The tricky part...
... is going to be in placing outlets in either the main or top parts of this gizmo if you expect to let them all rotate independently. If you limit the rotation of each section to one full rotation, it shouldn't be a problem. They make 14-3 stranded, rubberized wire that you could use to power your outlets, and it would withstand plenty of this sort of back and forth twisting. Use all listed components and you shouldn't have any problems.
(Just remember that it's easy for us to recommend stuff, but you'll have to assume responsibility if you decide to act on any opinion or advice you read here. I'm working on just this sort of disclaimer as we speak.)
The Device *LINK*
is called a "slip ring" if you want complete rotation without stops. The link is to a video as to how to make them. They are pretty expensive to buy ready made.
slip-ring
Yow! Great link. Thanks.
Re: The Device
William Duffield
Thanks, Mark. That was along the lines of what I had imagined, but the carbon brushes somehow hadn't occurred to me.
I don't have a CNC water jet cutter, but there must have been a method for accurately cutting this stuff long before those gizmos were invented.
Can I use walnut veneer plywood (poplar veneer core) as an insulator, or will I have to build the slip rings on top of something with a higher resistance? I have acrylic, but not phenolic, and not Garolite.
I can get copper sheeting from my local hardware store, so I don't think I need to use the more expensive brass. If I build them inside the lazy susans, between two pieces of 3/4" plywood, I shouldn't need any more protection than that, I hope.
Clint Searl
Clint Searl
McGiver would probably cobble something together out of skateboard wheels, a bowl of mercury, and 15 feet of #10 wire.
Rick L
http://www.mercotac.com/index.html
Re: The Device *LINK*
Bob Entwisle in NJ
William,
Your request got me poking around on the web, found this, not too pricy.
(unless you are in an experimental mood and really want to roll your own)
Plenty of this sort of thing out there, jsut have to search it out.
Bob in NJ
http://www.hurricanewindpower.com/slip-ring-3-conductor-rotating-electrical-connector/
Re: The Device
Bob Entwisle in NJ
Geez William, now you've really got me thinking about this.
I'd use a sheet of 1/2" thick delrin as a base for the rings. Delrin is easy to work, a good insulator etc. I use lots of it at work for electrical test fixtures and such.
Bob in NJ
Re: The Device
John McGaw
I have seen slip rings done with standard printed-circuit FRP material, probably with 2oz copper and phosphor-bronze brushes but with those materials it would be a rather low-current device and probably not up to the sort of use you envision. Is it absolutely essential that the plugs rotate in your application? I'd be inclined to make a stationary top containing the plugs, easy to do since it could be on a 'stalk' extending through the bearings. Failing that mechanical stops could be designed to allow up to two-rotations of each platform and this would allow flexible wiring to feed the plugs as Ellis suggested. This sort of setup would be pretty much bullet proof.
John McGaw
Probably McGiver would have gotten to the bad guy's vehicle and removed the slip rings from their alternator. Which brings to mind the one place where one can find slip rings very readily. Alternator slip rings can certainly handle the current and I wonder if they couldn't hack 120VAC also considering that they are designed for really bad conditions under the hood of a car.
walta
The commercial device looks like a great idea.
The home made one is nice but is way too dangerous to allow people anyway near.
Let’s play what if.
1 Lets say a 2 year old child gets near this thing and is able to their fingers on that copper. What will you say to the mother if the dead child?
2 The unit worked well for 5 years but the salt air has corroded the copper. Now when turning the brushed are sparking. The uninformed cleaning lady sprays the unit with lemon Pledge while it is spinning. The spray ignites and the building burns to the ground.
Let’s please play it safe with electricity.
No wood is an expectable insulator at 120 volts.
Walta
Re: The tricky part...
William Duffield
I don't think it would be practical to limit rotation to 360° for this application. That is a limitation I find particularly annoying for the work lights I use in the shop. Even though I try to be ambidextrous, I still have the tendency to rotate everything in the same direction.
Re: Electrical Slip Ring
William Duffield
Thanks, all! Now that I know what they're called, it makes it a lot easier to find what I'm looking for. Except, maybe now I know too much, and have to decide whether I want to also wire it for Ethernet, telephone, CoAx, USB and/or HDMI, etc. :O Of course, the more wires the greater the cost, and technology goes obsolete a lot quicker than fine furniture and printed books.
Walta, you make some very good points. I am well aware of the risks. Having wired my shop, rebuilt machinery and appliances, and used lots of solvents more flammable than Lemon Pledge, you can rest assured that if I were to build my own slip rings, they would be enclosed more securely than any light switch or electrical socket they were feeding. Also, I will most certainly install a GFCI in the base.
I would choose a simpler solution
I would not find it a burden to limit the rotation to 359 degrees. Then the wiring task becomes simple and reliable and one can focus on the woodworking. The kind of cord used on appliances can withstand flexing in use. So, the only problem to be solved is a secure connection that will withstand flexing. Again, appliances offer a solution to this problem.
Cord recoil from a vacuum
Tom Dunlap
Many years ago I scavenged the cord recoil from a vacuum. The power for the beater bar head went through the recoil using this type mechanism, with the ring. I bet a trip to a vacuum repair shop would find one. You'd need to check and see how much power it was rated for.
Tom
Re: Cord recoil from a vacuum
I think I'll make a trip or two to the dump, and see if I can canibalize a couple of trashed ones from there first. It's a great idea, Tom. My shop power cord reel might provide suitable components as well, and the Borg might provide a couple of them rated for more amps for less than the vacuum. I'd get some more extension cord and some outlets thrown in to the deal at no extra charge.
