How to use a 1/8" bit shank in a router
Roger LeBas
Hello,
I know if there is anyone who will know how to solve my problem, they will be on this site.
I do cnc engraving. I use a porter cable router with a 1/4" collet. I need to use 1/8" ball end mill in the router for the engraving. I know of no way to insert a bit with a 1/8" shaft in the router and have it to run true, without any wobble. I know there are other bits that can be used, but I find the 1/8" ball end mills work best for my use, and hope that I can find a fix for my problem. I have tried using a drill chuck to hold the bit, wobble, wobble, wobble.
If there is someone out there who knows how to solve this problem for me, would you please let me know.If some needs more information, I will be happy to supply it.
Thanks,
Roger
