Not much from me this week as I've spent considerable time working at the day job working on problems and new setups. I'm hoping for a much quieter week this week at the day job. I'm gearing up for making the LOML Jr a cedar chest for storing her blankets and such. She also wants me to make her some other items that they need for their home, so looks like I will have plenty to do over the winter months.
Spent some time riding motorcycle with my motorcycle group this weekend and we all attended a local church that was holding a "biker Sunday". We had a good time riding with the church group as well as attending their service with them, then it was good food after the service. An awesome day.!!
Well, that's it for me....so what did YOU do this past weekend?
...where the rain gets in, and keeps my mind from wandering.
Actually, thank goodness, it hasn't been getting in*, thanks to several layers of temporary fixes; but it's time. Last Fall, before my bride's surgery, I installed grab rails in our tiled shower. Turned out the blocking we'd put in the wall for future grab rails, when we did the shower two years back, didn't go quite as far as I thought, so I had to cut holes in our wood siding to install blocking for the screws at one end of one grab rail (two: one hole for the blocking, after cutting the first hole one stud bay too far; oops). Thanks to duct tape and Visqueen, we made it through last winter without any water incursion, but it was time to fix it before this year's rains set in.
The siding is fingerjointed cedar, and I cut beveled/tapered plugs from scrap trim boards (also fingerjointed cedar):
I then used a guide block with the same bevel to shape the holes to accept the plugs:
using these tools:
After a lot of phone consultation with various manufacturers, I wound up using vinyl spackle as the adhesive. This fills the (minor) gaps in the glue joints (more so than Titebond) and will be sandable (more so than caulk) and paintable (more so than the epoxy available to me here in my little town). I taped a stick to each patch, slathered up the hole and the patch with spackle, and screwed sticks across the patch, bearing against the stick on the patch, to put pressure on the joint.
Tomorrow (probably), I'll sand the patch flush, spackle the multiple screw holes made in the process of getting the holes ready for the patches, and paint. It will be nice to get this off my list of things I gotta do.
*And, anyway, my mind could wander if World War III had happened and the zombies were surrounding the property.
Pulling the whole board would have required pulling trim in two places, which overlaps the wrong way in one case, so lots of trim.
I considered cutting through the siding and patching in a new piece. That might have been faster, although getting the end joints weather-tight would have been tricky indeed.
short of replacing it all, that looks like a pretty good solution, Bill. Did it turn out prety level with the rest of the siding? What is that, shiplap?
I recently submitted a similar bed in shop shots. This one is a 54" wide double size for my wife, as she really liked the one I built for our daughter. She wants it to replace a pine cannonball I made years ago. This one I have made changes to the shape of the head and footboard.
