Tinting Poly follow on to banister question
Dustmaker Mike
Well the wall prepping and painting is done. So now it is on to the banisters. I have taken them off and started to clean them with a scotch bright sponge and warm soapy water. It seems the finish is old enough that it is coming off pretty easy this way. It is still leaving a light golden oak color because they used a better stain then finish on it. So here is what I am planing on doing.
Get two gallons of Glossy Poly
Tint one to the color my wife wants
Put two coats of clear gloss on then one coat of tinted sanding in between each coat.
Now my question what do I use to tint the Poly? I want it more brown to walnut in color.
Does this sound like I am on the right path. I will doing the same treatment on the new treads and a bench seat I am going to be replacing and building.
As Always Thanks
