OT High speed internet access
Merle
I live in NM and have "high speed" internet through CenturyLink via DSL. Cable is not available where we live. Is there any other technology available that offers reliable high speed internet service? When I have contacted CL they tell me that there is no problem with their service, so it must be my hardware. I used to believe them and have replaced my modem and wifi router to no avail. For the last 3 hours tonight, it has taken up to 5 minutes to load a single page. There has got to be a better option. Thanks for any assistance.
Re: OT High speed internet access
Merle, any DSL connection should be more than adequate to load pages in seconds. I suggest you call your DSL tech support and have them walk you through whatever it is that is holding you back.
paul in AZ
As I understand it there are countless reasons for slow DSL downloads but the biggest of all is distance from the phone company's server. The longer the wire the slower the service. Their advertised speeds must be measured from a computer across the street from the phone Company.
Years ago I had a wireless connection that was faster than the old telephone modem but still very slow by today's cable standards.
Perhaps there is a satellite service. I don't know.
craigd
Re: OT High speed internet access *LINK*
craigd
DSL can be flakey for a lot of reasons, such as a long cable run (between the phone line drop (pole) and the modem). That is one thing the phone company can test (I kinda remember it as a test they did remotely but maybe we had a tech come out. I seem to remember the distance as over 1000'). Also the phone line itself (such as dirty contacts, crosstalk between the wires, electrical interference, etc).
I haven't seen any issues with Cat 5e cables (the Ethernet cable between the DSL modem & computer or router) surprising enough (100's of cables of various brands).
Unless you can beam WiFi between you and a friend with cable or use your cell phone for 'net access (also not fast) you could be stuck with DSL.
Here is a link to a broadband speed test, which might give you some ammo when talking to the CL tech about what they advertise and what you got.
Edit: As Paul mentioned, satellite may be an option, fast (ish?) down, slow modem up.
http://www.speedtest.net/
John in NM
I got the same run around with our provider until I told them I can ping my router just fine. Then the kid on the phone said "what's ping?" and got nervous and found me a real techy (I've learned not to say "linux" until I'm talking to that guy :D ). Turns out a card was bad in one of their upstream computers.
Even on systems where terminal windows and ping commands are long gone (or such gritty details are well buried :D ), there should be some kind of utility available to test the connection to your router - if that is fast and your computer is fine, then you know the problem is theirs, not yours.
Since that one problem, our DSL has worked quite well, almost as good as the connection at work. I would say there is a problem somewhere in your connection, whether on your side or the provider's.
RobCarr
Change you DNS servers to:
OpenDNS
http://www.opendns.com/support/
208.67.222.222
208.67.220.220
or
Google free public dns server
http://code.google.com/speed/public-dns/
8.8.8.8
8.8.4.4
If you still have problems, use "tracert" at a command prompt and it will show you exactly where the link fails.
Another thing to look at is telnet to "192.168.1.1" this should be your DSL router and make sure the parameters are set correctly - things like TCP/IP MTU settings.
run a speed test here
del schisler
check here http://www.internetfrog.com/mypc/speedtest/ than you will know your speed than you can tell your provider
Bill Howatt
By all means run a speedtest.
Do you have somebody else in the house that may be doing a giant download when you are experiencing problems?
Has it always been bad or has something changed?
Does it do it on other websites as well?
Does it do it all the time?
If necessary, do you have any filters for other devices connected to your phone line installed. If you have a direct phone line in your house for your DSL modem, there may be just a single filter for all the other devices. The DSL modem line is not filtered.
Can you go to a neighbor's house and try the same sites on his computer? If it works then you have a problem specific to your setup or line. At the telephone line's central office there is a card that deals with the DSL signal on your phone line. The channel dedicated to your line can go bad just like your modem can go bad.
Bill
John McGaw
What sort of modem do you have? Every modern DSL modem that I'm familiar with has troubleshooting aids built in which will tell you what is going on. These would include logs of errors corrected/uncorrected, noise margins, and attenuation at the very least. Most often accessing this information is a simple as entering the IP address of the modem into the address bar of your browser which will usually open a locally-generated web page with access to the various functions which the modem supports.
In my experience, DSL is most often a problem when the local telephone wiring is, to use the technical term, flaky. This can mean elderly copper wiring with bad connections, moisture where it shouldn't be, defective or improper protection blocks, filters malfunctioning. Sometimes figuring out where the problem lies is as simple as asking your neighbors who use the same ISP if they've experienced problems lately. Sometimes a problem affecting multiple users will be in the DSLAM (Digital subscriber line access multiplexer) servicing them as a group. Other times it will be your specific wiring from the DSLAM to your modem.
Making DSL work well is not an easy task since it requires the copper wiring to do something it was never meant to do -- carry a high-frequency RF signal. A fiddly little problem which would not affect regular telephone service will totally screw up DSL and it takes a dedicated knowledgeable technician to track down the problems sometimes. If your ISP is letting it slide and isn't sending someone out to do the proper tests at your house they aren't doing enough. DSL can work and work pretty well even in locations with bad conditions -- my DSL has been refined well enough to give me a reliable 11-12mb/s despite 1959 telephone infrastructure and a DSLAM on the very edge of being too far away to use. I just had to make myself a total PITA to AT&T on a continuing basis until they did the right thing.
Merle
First, my thanks for all the responses!
Here is additional info based on Bill's questions:
"By all means run a speedtest." The issue is sporadic, but speedtest.net usually won't load when the issue is happening. That is to say that it times out before the page loads.
"Do you have somebody else in the house that may be doing a giant download when you are experiencing problems?" No. Normally, I can have Pandora running and still function normally, but when this issue starts I close Pandora and still have horrendously slow service.
"Has it always been bad or has something changed?" As mentioned, it is sporadic, maybe every month or two and lasts for 3-4 hours, then seems to return to normal. It has occurred in the morning, afternoon and evening so I don't think it is a bandwidth issue.
"Does it do it on other websites as well?" Yes, across the board.
I have a Linksys Wireless router WRT54GS and the modem is a Netgear DM111PSP v2.
Chuck in Mtl.
if you run a speedtest under normal conditions what do you get?
Merle
I just checked and Ping=70ms, Download=1.27Mbps & Upload=0.72Mbps. Interesting some of the neighbors "upgraded" to 3Mbps service and didn't notice an improvement.
Bill Howatt
Looks like you are perhaps a fair distance from the backbone equipment. I'm 5Km (~3miles) from the local phone company's office and get about 2.5Mbps download.
I'm sure you'll find in the specifications the words "up to" preceding any speeds you will get with a particular service. I should be getting about 6Mbps but the distance and line quality precludes that. I did upgrade and went from about 2 to 2.5Mbps.
While your speed is not fantastic it may not be the real problem which could be something like bottlenecks or problems elsewhere in the system that doesn't even let you get going with downloading information.
I don't know if the provider doing maintenance is a possible cause. It could be that something else is happening in the chain at times that is sucking all the bandwidth before it even gets to your line or an equipment failure .
Bill
Verison
I have Verizon 4G and it has been reliable and fast....10+ Meg/per something or another.
Re: Verison
Merle
Good suggestion, but no 4G in my area. Thanks anyhow.
Merle
We are about 3 miles from the base and are only paying for 1.5Mbps, so when it is working it is okay. However, if there were a different technology/provider in our area I would move in a heartbeat.
AT&T
Yonak
Merle, cell and satellite service is all we can get. We have AT&T 3G service and, while it's not blazing speed, at least it's reliable .. no aggravating slow times like we had with HughesNet.
Re: AT&T
Merle
Thanks, Yonak, I will look into it a little.
Jim Dillon
Don't know if a WISP (wireless internet service provider) is available in your area, but it might be another option for you to consider. We have been on one for a couple of years at our cabin in rural Virginia. Various options were offered and higher speeds were available if we had had line-of-sight to the transmitter, which we did not. As with cable, bandwidth seems to vary, but it has served our basic needs and sure is a lot better than dial-up. DSL or cable are not available at this location.
We have Verizon DSL at our other house and we generally get the speeds we pay for, but momentary internet (generally not DSL) disconnects happen. The Verizon service tech said the disconnects are due to the lack of capacity at the point where the DSL enters the internet about 40 miles away.
Here is a web site to find out whether a WISP is available in your zip code:
http://www.wispa.org/find-a-wisp
Merle
Jim, this seems to be just what I wanted. I called the local WISP and they give the same speed I am currently paying for, but not getting, for a lower cost. Thank you for the suggestion!
Jim Dillon
Merle, be sure to read the fine print in any contract you sign. As a previous poster said, the "...speeds up to..." is almost always used regardless of the provider. Since WISP is usually provided by a local vendor, I would speculate that the terms of the contract can vary a lot between vendors. Mine, run by a local computer store, is on a month-by-month basis, with NO download limit. The download limit caveat is important if you intend to stream music (as I do), movies (I don't), software (sometimes) etc. My provider also required that the receiver/antenna equipment be "purchased" with an option to buy back a portion of the equipment (1/3) if I was not satisfied. There was also a 30-day money back guarantee.
Anyway, glad I was helpful and good luck.
Jim
Merle
Thanks, again, Jim. Morte good advice.
