OT Ignition Swicth Question
My Honda CRV Is getting a little long in the tooth, but its not time to buy a new one. Yesterday the ignition switch started getting glitchy. Its like it has a grit in it. The key won't go in but about half way. You wiggle and jiggle and find the sweet spot and it will work. I blew it out with compressed air. I squirted graphite into. Worked it over and over with the key. Blew it out and tried again. Not sure its any better.
Anybody got a clue? Is there a liquid lube that might work? Can the mechanism be disassembled, cleaned and reassembled? Who does that, dealer or locksmith? Could the offending parts just be removed and I use the key like a screw driver?
(Its one of the newer keys with the pattern on the surface, not teeth on the edge.)
Re: OT Ignition Swicth Question
John Veerkamp
Several electronic parts lubes available including graphite suspended in thin oil. Lock Ease is one brand. Any hardware store or box store will have a selection. Even Target and Walmart.
Try a good liquid lube. Nothing to lose if it doesn't work. Your best bet if it's really worn is to take it to a locksmith. I pulled the lock out myself and took it to them and they were able to fix mine. Replacing the lock is rediculously expensive. They told me they had to "re Key" the car and it would be $300. I told them in no certain terms what they could do with that electronic key. The locksmith fixed the lock so I didn't have to go through all the electronic mumbo jumbo the dealer said it needed.
John in NM
Sounds like the tumblers are wearing out.... or whatever they are called in a new fangled lock :D
There isn't really any fix for it, other than replacing the lock or bypassing it, which may or may not be possible on a new fangled car with said new fangled lock.
I've heard locksmiths swear up and down about every lube that people put in locks. I've never figured out if that was because they didn't help but made for messy work later, or if they did help and thus denied the locksmith business :D I avoid anything except dry lubes in locks, but then it's so dusty out here that the rationale becomes obvious quickly. Probably not a problem in VA :D
My pickup starts by the screwdriver method. One advantage is that I now always have a screwdriver handy :D
Brian from Monument
John, Are you practicing a new skill...... Grand theft auto?
Er maybe you own the vehicle... oh well. lol
Mark Nowicki
With all the blowing and spraying and blowing it probably does have more grit and gunk and whatever.
Dealers don't clean parts, they replace them.
Google " honda ignition lock replacement" and you will find many videos showing repair, removal, and replacement.
www.hondaautomotiveparts.com has blow-up diagrams, and prices for your model.
Mark
The pickup you mean?
John in NM
I did kind of steal it from my wife (it was hers before we met) :D
The condition of it's lock is just a sign of advanced age... but it was handy to have the screwdriver around before I fixed the tailgate latch - for a couple years I needed the driver to open the tailgate as well as start the truck :D
