love that picture, detailed color explanation
Some nice trails start at this lake.
I can't resist explaining the color. It is a result of the Tyndall effect, named for John Tyndall who was drawn to studying it after observing glacial lakes in the Alps. In addition to being a scientist he was a mountaineer and made major contributions on understanding the movement of glaciers as well as an explanation for why mountain tops are cooler than valleys (the misnamed "greenhouse effect"). (it is not how greenhouses work)
If the right sized particles are suspended in a liquid these particles will interact with light and scatter it at various angles to the incident light beam. An experiment to dazzle your children is to shine a focused white light beam through a glass of milk. The transmitted beam will be red as observed by placing a white card opposite the light source. The scattered beam, that observed at right angles to the beam passing through the milk will be blue. This kitchen table experiment demonstrates why the sun is red at sunset and the sky is blue. In this case the sun is the light source and stuff in the atmosphere does the scattering. When you look at the sun, you are observing the transmitted light, which is red. And when you look up you are observing the scattered light, which is blue. Were it not for scattering the sky would appear black.
These colors result from the fact the short wavelengths of light (blue) scatter more than long(red), if the particle size is right.
Back to the lake. The lake would appear black if no light was scattered back to the observer on the surface. Depending on the particle size of the glacial "flour" suspended in the lake the scattered light can appear blue or green as a result of the white sunlight scattered off the rock particles.
If it is still there, the Exploratorium in San Francisco has an enlightening experiment on light scattering where you can explore the angle and wavelength dependence of the scattering.
BTW, it is the same effect that enables radar to work. Given the optimum ratio of wavelength to particle size (in this case microwave to airplane) the radar signal is scattered back to the radar station.
