Sealing luan for PU varnish *LINK*
Tom Dunlap
The woodworking inside of my camper is almost completed. The walls are paneled using 5x9 sheets of luan plywood. The face frames and solid wood parts are a mix of ash, burr and white oak, buckthorn and aromatic cedar. The counter top is white and burr oak. After building the countertop I used a couple of coats of Watco followed by three coats of Minwax PU varnish.
While I was doing that finishing I wanted to see what the luan might look like with a finish. I put the same treatment on a part of the wall as I did the counter top.
Now that the counter top is installed...it looks fanatastic...I look at my test patch on the luan and it sure is disappointing. Even after applying a couple more coats of PU the plywood is still rather dull looking. My hope was for a bit more smooth satin finish like I got on the solid wood counter top.
After reading a lot about sealers it seems like they don't 'seal' the wood like a primer would on metal or for paint.
Now I'm confused.
This article came up in a Google search.
If I don't get the walls varnished soon I'll wait until warm weather in the spring.
Am I missing something or do I have expectations of PU on luan that won't be met?
Tom
Minwax sanding sealer
Re: Sealing luan for PU varnish *LINK*
Keith Newton
Tom, I don't have any finishing help, but reading that you used Bur Oak, and some Buckthorn in it made me chuckle, and wonder if there is a story behind those two?
If you put on enough to fill the porous grain it will eventually shine. No secret to success- varnish, sand , varnish, sand, repeat till it looks like you want it to. However, it will always look like Luan, which may be the least attractive wood there is. And it will be dark which will make the space feel smaller. Personally I would have painted it a light color.
You want a high solids finish. No problem there; all the urethane varnishes are high solids. In fact I usually dilute them to make them flow better.
metal primer is designed to promote bonding and mitigate corrosion. No relevance to wood coating.
grain filler *LINK*
Dick Coers
is a material that few seem to know about. You can get it in neutral or tinted colors. It used to be standard fare for filling open pore woods. I would suggest a reddish/brown color so it would add some pop to that bland wood.
behlen video
The wood *LINK*
Tom Dunlap
The luan paneling has a grain that I want to keep. I chose the sheets specifically because of the patterns.
The rest of the wood came from trees that I removed and had milled. It's not hard to get almost any species of oak and ash is abundant because of the Emerald Ash Borer killing so many.
buckthorn on the other hand is rare as a wood. It's a nasty, invasive species too. One that I took down had a large trunk with some interesting character. I had my sawyer slab it through and through about 3/4" thick. My plan was to make boxes or picture frames since the useable wood wasn't going to be very wide. Along comes this project and I found a use. At first I glued up the counter using strips that were 1-2.5" wide. The wood is very pretty. Then I decided to use wide slabs of white and burr oak instead. Since I had the glued up panels I used them to make a cubby hole on the top of my skinny cabinet. I'm anxious to see it all with a nice finish.
I shared some pics with Bill Tindall. He said that he was reminded of 'A Coat of Many Colors'. True enough...by using so many species the ToyBox may look a bit patchy or hodge podge if my goal was to do fine cabinet making. My goal was to use wood that I had to fit my purpose. Using the many species has worked out OK.
It's not easy to see but the plywood faces for the cabinet is taken from one sheet of plywood. Starting from the lower right corner of the sheet and moving across the bottom I cut out the faces for the lower cabinets. Then the sides and face of the tall skinny cabinet were cut from the left side of the sheet. The grain pattern flows from one panel to the next.
The link has some pics of the build. I'm going to add some of where the cabinetry is right now.
Tom
ToyBox
don stephan
You might try some experiments on a scrap piece of the luan. What's not clear is how the surface of the luan was prepared for your varnish test. What progression of sanding grits was used? Was the raw surface smoother than the varnished one?
Your connection to the face frame woods is great.
Surface-Don & Bill T.
Tom Dunlap
Don,
The wood was smooth, I sanded with my ROS before Watco/varnish. The plywood was sanded too but the surface will never be as smooth as the wood. The grain is much more open, not cracked, but not smooth. Before I put the PU on the plywood I sanded to the same grit as the wood. It's smooth to my touch but still there is a rough texture.
I've never finished anything this large or with so many variety of woods.
Bill,
My comment about metal primers was more in line with preparing the surface to grab onto the final paint layer. Conceptual not technical.
I agree
Lauan plywood is extremely porous, plus it is usually rotary peeled veneer, which tends to have a lot of tiny checks in it. This makes it a questionable choice for a finished surface, but here you are. As Bill mentioned you can varnish/sand/repeat until all the pores and checks are filled, or you can use a pore filler at the outset and start with a dead smooth surface that will yield a nice finish with just a couple coats of your varnish.
I like water-based pore fillers, and you can tint them with universal colors or water-based dye stains to get a complimentary or matching color. Squeegee it in across the grain and sand it when dry to get back to the bare wood.
filler?
I have filled a table top. I can not imagine filling a 4 x 8 sheet(s) of plywood. maybe other's technique is more efficient than mine.
He didn't say he wanted it smooth. He just wanted it to have some gloss and not look "dead" like luan looks. Pores don't need to be filled glass smooth to achieve this end. Just need some finish on the bottoms.
Re: Surface-Don & Bill T.
If you are going to paint it prime with Kilz then sand with 180 grit. It is extremely high solids and will largely level the surface but leave some texture.
Re: filler?
"Even after applying a couple more coats of PU the plywood is still rather dull looking. My hope was for a bit more smooth satin finish like I got on the solid wood counter top."
Maybe I misread his intention. Regardless, there are ways to fill or partially fill pores, even on large surfaces, that needn't be difficult or daunting. You have to understand the distinction between "wood filler" and "pore filler." I used to make my own pore filler by diluting water-based "wood filler" such as Elmer's to a wiping consistency. By varying your technique, you can achieve a partially filled look or a completely smooth surface. By adding stain, you can match or contrast the pores with the surrounding wood.
Regardless, it is an interesting challenge to make lauan plywood presentable. I'll be interested to see how it works out. I hope we'll see some pics of the finished project. Sounds like fun.
Re: filler? and a question for Tom
I tend to agree with Bill. I saw this as "daunting". The filler I have applied would be though to get it onto and off of large surface. Will have to try Ellis' method, but I hope this never comes up for me.
Tom, were the sheets really 5x9? Or were they 4x8? I have never seen luan in 5x9 and it might be handy sometimes. Where did you get it if you really got 5x9 and how much did it cost?
I agree with Ellis
Keith Newton
Luan isn't much to look at in it's natural state, but it was used a LOT in those old wooden boats like Chriscraft where it was stained and filled darker and finished heavily. Then it looks more like Genuine Mahogany, yet is lightweight.
Even if you don't use a paste grain filler, you could bring some of the pores out by using a liquid / cream wax after all your finishing is done. You could go either darker or lighter than your base color, to bring the grain out.
5x9...yup
Tom Dunlap
There's a place in Asheville called Scroungers Paradise that has the plywood. Yes it is really 5x9 too. They have lots of ipe and other interesting wood along with odd and interesting bits and bobs.
The cost is $15/sheet
Wow, that amazing...
At $15 its the same as 4x8 at $11. Usually have to pay a serious premium to get over sized stuff. Wonder what the application is that demands it, other than your camper, of course.
I will have to check around and see if its available locally. Don't know what I would use it for, but you never know when it might come in handy. Come to think of it, I bet there are a lot of bathrooms where it would do the floor in a single sheet or at least eliminate a lot of seams.
