I need to shorten my formica counter top 3/4-inch and must do it as it sits in place. I figure on using my Bosch jig saw, then an oscillating trimmer on the back-splash portion where the saw blade cannot reach.
Naturally, I'm worried about chip-out on the top. Any experienced suggestions on what blade to use on the jig saw? I have a hand-held belt sander, so I can cut it long, then sand to the finish line.
Put the best tape you have on the laminate before cutting. Cut through the tape. Don't use an aggressive blade, but really can't say how many teeth, sorry. It will also chip less if you do not put the blade on oscillation. Straight up and down will be the best. Make sure the base of your saw is smooth, maybe tape it so you don't scratch the laminate.
I've done this using specialty blades that cut on the down-stroke. The big box stores carry them, so you should be able to find one easily enough. Practice on some scrap first to get a feel for the blade, because they will make the jig saw want to jump up, then dance around on the Formica. DAMHIKT Go slowly and let the blade cut at it's own pace - don't try and force it.
T101BR, as was mentioned it cuts on the down stroke. Also, make sure the base of your saw is smooth and that no little chips get between the base of the saw and the laminate.
You can get a laminate scoring tool, which is just a single carbide tooth on the end of a hook knife. With it, you hold your steel framing square down for a straight edge, then make about 5 scratches, which get progressively deeper. Normally you can bend and snap a sheet, but here, you could use a circular saw down the waste side of the kerf, with no worry of chip-out. You could even use your jigsaw, but it will be easier to see than a pencil line.
I agree with all of the above. I would score it, tape it, cut it on the waste side of the score (about a 1/16" on the waste side) and sand it into submission. On the part I couldn't get to I would use the oscillating tool (a Multi-tool?) and I would clamp a guide block to it and cut beside the guide block. If I did not have a scoring tool and did not want to buy one I might use a razor knife and straight edge and then deepen the score with the multi-tool.
Another approach would be to use a router , preferably with a down cutting spiral bit. You probably would still have to finish with the oscillating tool.
Don't know why you are cutting the top, but it the it the end is to be left even semi exposed, like nest to a range or something, you should seal it with some sort of finish. The sub-straight (sp?) is not in the least water resistant.
This was to widen a space for a new refrigerator. I used an iron to heat and remove the formica end trim. I used a 24-inch square to scribe a line using a plastic scoring knife. I then taped the counter top and taped the square to the counter top as a guide. I used the down-cut blade to cut along the scribed line. On the back-splash rise, I used a disc shaped cutter on the multi-tool to freehand cut along a scribed line. This allowed me to insert the cutter into the cut made by the saber saw before starting the cut on the back-splash, which helped to keep a straight cut. I then used my sander to smooth the transition lines. I cleaned the old glue from the back of the end trim with a scraper and reglued it to the counter top.
The down-cut Bosch blade cut really, really clean. Only one complaint with Bosch. I used the saw left-handed and when I got to the end of the cut and released the trigger, the saw kept running because of the stupid location of the button that locks the trigger on. The saw did some jumping until I could get a second hand on the saw to release the trigger. I keep saying I'm going to disable it, but I have a hard time bringing myself to disfigure a fine piece of equipment.
Thanks again for all the suggestions. It turned out great.
