Friend call to ask how to remedy some candle drips on his new dining room table without harming the finish. My tendency is to do a bit of careful scraping following by MS to disolve the remainder.
On fabric, my wife takes a soft cloth and places it over the wax and then irons it with a medium iron. The cloth absorbs the stuff from underneath. I don't know if that would work, but it might be worth a shot.
My first inclination is to suggest trying the remedy on the underside first to see if finish harmed, but to wait a few weeks if the dining table finish was applied within the last few weeks.
Any abrasive, including nylon dish sponges, may be strong enough to mar the finish and change the sheen. I might try scraping with the edge of a tongue depressor if it doesn't mar the finish on the underside, to remove the bulk. Naptha is often recommended to remove furniture wax, not sure if it will work on candle wax, not sure how many homeowners have a can of naptha available. A clean rag first warmed with a hairdryer may soften the wax enough to wipe off the remnants if solvent isn't available.
It would help a lot if he knew, and told you, what the finish was. Also, what the candle was made from can make a difference, as well. For example, Ikea candles are styrene, which acts differently than tallow or beeswax or parrafin candles. In general, naptha or mineral spirits works, but the first thing I try is an ice cube. After it's cold and brittle, the wax blob often just pops off with a little pressure under the edge from your fingernail.
Google "remove candle wax from table". In general you freeze the wax and chip it off. Do not heat it. All that will do is liquify the wax causing it to be drawn into the wood.
Isolate some ice with a piece of plastic or aluminum foil and get the wax cold. It will likely chip off. If the finish is lacquer any remaining film can be removed with mineral spirits or furniture wax.
This was my though too. Place a piece of foil on the wax and an ice cube on the foil. (The foil will keep the water form the melting ice off the table, but not for long. Soon condensation will form, defeating the purpose, but it may buy some time.)
Chip it off with a finger nail and then buff the entire top.
