Corian Countertop
Corian Countertop
Corian Countertop
Kelly M. Robison
I have to take out a counter-top stove unit. The "war dept" wants to put in a new gas stove with oven. My problem: Once I get the counter-top out, I will have to cut the existing Corian counter and clean up the cabinet to make room for the new stove. The new stove is 30" wide, so I am going to give myself a fudge factor and cut it 31-1/2" wide. I will finish off the ends where the old cabinet ends. What is the best way to cut the Corian?? I am a wood turner and have never worked with counter tops. What is the best tool to use? Thanks for the input.
Kelly in Port Orchard
Re: Corian Countertop
Keith Newton
Kelly, You can cut it with about anything. It cuts fine with a fine tooth circular saw, jig saw, or even a router. Of course, none of those will cut all the way into the back corner, so you may need a handsaw, or a reciprocating saw back there.
I'm not sure why you are wanting to cut the cabinets out over 1/4" larger than the stove. That sounds like a declaration for war, if you leave that much room for crud to get into, yet not enough room to clean out around it.
Howard Acheson
Cut the Corian with a high tooth count carbide tipped blade. 80 tooth works well.
Jerry Nicholson
Very easy stuff to work. Try turning some of it. Sharp tools are best. I have cut it with a tablesaw, jigsaw, and bandsaw. Inside corners should always be round and smooth or you have the danger of cracks propagating from those corners. I have used hole saws and routers to make inside corners. Carbide edged router bits should be used as Corian is abrasive.
Jerry
Agree with Keith
I would allow no more than 1/4" total clearance between the counter top and the range. If you need end panels for some reason, put them under the top.
To get a nice straight edge, I would suggest cutting it with a spiral bit in a router or laminate trimmer, using a fence to keep the edge perfectly straight. Do it in successive small passes and always feed the router from left to right against the fence. You may end up with a couple inches at the backsplash where the router won't reach. You can cut that out with a sharp saber saw and file the edge flush with the routed edge.
My 2¢
Ellis Walentine, Host
Re: Agree with Keith
Tom
If you cut it while in place have an assistant hold a vac as the cutting produces ALOT of dust!
backsplash?
Dick Coers
On or off the cabinets? Need more details. Switching from a power saw to a hand saw at the backsplash will really be hard to hold on a straight and vertical line. You'll also run into various thicknesses. They build up the front, and the main section is much thinner. Will this thinner top be okay at the stove? Another reason to keep it snug to the stove. A little burger grease will find it's way into the cabinet if they didn't add spacers over each cabinet box.
I have been building cabinets for over forty years, off and on. (mostly off) I remember the very first set we built. We asked the manufacturer for a cut diagram for the stove/range. They said "Oh, just make it thirty inches." We eventually found it is was closer to 29.5". My advice would be to look at the stove and measure it for yourself. I have done three or four in the last couple of years and found that the free standing ones will fit nicely into a 30" opening. Not 29 7/8,... 30". If you make the opening 30 1/2" it will look like you can throw a cat in with it.
Some ranges are left flanging or what ever. You need to know before you start. We bought the flanges for some of them along the way. The War Dept will not like them, they are crud collectors.
Also, the ends of the cabinets generally need to be flush with the (new) end of the counter tops. At least the face framed does. And they need to be nice and plumb. The Range will need to be level and plumb.
Kurt
If you want to know all about Corian, you can find DuPont's installer manual online, either printable or html with bookmarks. Short version, DuPont recommends a router if possible. A triple chip carbide circle saw blade is fine. They do not recommend reciprocating anything. Apparently the stuff can get microcracks that may not visible to the naked eye but can propagate and become quite visible (!) at some later date. Of course if there's no way to get a circular saw or router where you need it, you gotta do what you gotta do. If you can get a hand saw where a router or circle saw can't reach, I think that'd be preferable to a jig saw. I've read that Corian and other solid surface sheet goods are soft minerals sorta like bauxite suspended in an acrylic or other plastic matrix. The soft minerals will dull steel cutting edges but I'll bet a hand saw would cut a few inches and require only a sharpening. If you want to know all about Corian, you can find DuPont's installer manual online, either printable or html with bookmarks. Short version, DuPont recommends a router if possible. A triple chip carbide circle saw blade is fine.
Rusty Fenn
If you can flip it upside down. Then you can cut the backsplash in 1 fluid cut. Just have to cut downward to cut backsplash. You can make a simple L shaped fence to guide saw or router.
