OK, so you probably wouldn't want to put a bunch of drinks on it for fear of spills but the beauty of the idea and implementation really knocks me out. The thought of big chunks of wood floating in air is so far beyond the norm that the mind boggles.
Impractical, but interesting as all get out to look at. I like the illusion of the floating cubes, but I'd like it better if it were firmer and had a glass top on it. All those veneer edges are damage waiting to happen though.
This may look like magic, but a nightmare waiting to happen. There is no way I would send that out to a home or office atmosphere.
Just sitting a smart phone or iPad on top of it would risk loosing everything out of it's memory. Those have to be some really large super magnets in there. I'd like to know for certain what would happen, if a phone was knocked off, dropping into the space down to the floor.
Wiping all of your credit cards' code when a wallet/purse got near enough, or erasing your primo collection of 8-tracks and audio/video cassets placed there for a moment.
Knew a guy in grad school who was working with air-suspension applications. He was doing mated spun metal bowls that were then "levitated" with an air compressor feed to the stationary base. Amazing how much weight could be floated with the air. Problem was with the hissing noise. He did do a side table though you could only put something dead center or it would tilt the top bowl and slid off.
Late 1960's I read about the new Allis Chalmers HD-41 bulldozer. The largest in the world at that time at 70+ tons. The assembly line wasn't of the usual type. The bulldozer was built in a jig mounted on a large thick steel plate. There was a 1/2 horse power motor mounted on the steel plate that forced air under the steel plate until it "levitated" the dozer and that allowed two workers to push the dozer from station to station. In the end the story wasn't about the dozer or the assembly line, it was about how they milled the concrete floor so smooth/flat that they could do this.
in the manufactured home industry. They'll frame it up on a platform that float the structure to the next phase location in the factory.
For more info, Google "air casters".
There is a real danger in it. that being inertia. The dozer or house is easy to move, but not so easy to stop moving. The levitated object is not weightless and, once moving, can easily get away from the guy pushing it.
I played with making an air caster plate to move my 850 lb wood lathe around. a) my floor wasn't nearly smooth enough and b) the pillows I made blew out. Still playing with the idea, but the lathe gets moved on a dolly for now.
That is actually a pretty standard materials handling strategy. You can buy those. Being me, I always wonder how much you could make out of ply epoxy, and levitate with the shop vac. Unlike vac bagging there is no limit to positive pressure (though in practice there would be). A few pounds per square inch, and you can lift hundreds of pounds.
Why would one lose everything from a smart phone or other modern electronic device? Magnetic memory hasn't ever been used in those applications that I know of. And in any case the nearest magnet would be a good 6 inches away from any device sitting on top and that won't do anything to even a magnetic storage device. Don't forget that computer hard drives contain some of the most powerful magnets that most regular folks will even come into contact with and they are only an inch from the storage media. It takes an amazingly strong magnetic field in close proximity to have any real effect even on a credit card with exposed stripe.
Let's use your laptop for the guinea pig. The last time I bought even small supper magnets, they came with a warning to keep them away from smart phones. These have to be pretty large to suspend everything above.
Is it really levitated with magnets? How long will it take to get all the metal crap out of the cracks? It would weigh eight hundred pounds before I could get it out of my shop.
Could anyone repair it if/when one of the cables break?
I did some test a few years ago with several shop vacs, and the average was around 150# per square ft. of area an the negative side, so I assume it would be the same on the + side, but that may not be the case.
Thanks for posting John, those are really cool and totally impractical but I would buy one if I had the money.
I think one thing that gets lost is that the craftsmanship on them is really good, so many times things like this are more about the concept and not about quality.
This thread is going on entirely too long but I'll just quote what you wrote and what I replied to: "sitting a smart phone or iPad on top of it would risk loosing everything". That said, I wouldn't fear placing my notebook on top of the levitating table since it now has an SSD for its main storage as do most modern units but I wouldn't have had trouble with putting it there before its transplant because I have actually gone through the experiment several years ago, trying to erase a laptop drive using an external powerful magnetic field and failed in the attempt (I found it impossible to achieve a strong enough field gradient from outside the case let alone several inches away as would be the case of the table).
But just to be clear, you said. "trying to erase a laptop drive using an external powerful magnetic field". Was this using rare-earth magnets, or just a big standard magnet?
I don't claim to be an expert on magnets, but a year or two ago, I had a few that I was playing with. I tried pushing a rare-earth magnet against a standard magnet. I was surprised that it was getting harder and harder, then bam,,, it went together. I questioned myself, did I not know that it just flipped in my hand? No, it reversed the poles of the weaker magnet. I hadn't expected that.
John, it would be nice if you would post a little something about yourself in your profile. I seem to remember from some of your earlier post that you had some sort of computer expertise as your occupation?
I did my experiment on an old small capacity 2.5" laptop drive and wanted to know if it was possible to wipe it for disposal without resorting to physical destruction. I placed a 3/4" rare earth magnet on on the metal side of the drive and wiped it around and found that no detectable data loss occurred. Then I tried a magnet on each side, attracting each other to concentrate the flux and found that the drive was still readable. I then tried a 1" rare earth magnet on each side and that did something after a while but it only seemed to increase the read error rate but it never made the drive truly unreadable. Perhaps actually spinning the drive under power with the magnets in place would eventually wipe it but I could never be sure that everything would be truly unrecoverable so I placed the drive into a vise and whacked it with a dead-blow mallet to bend it at a right angle. That always works.
