Macassar Ebony Door (Moving Wall)
Hikmet C. Sakman
Hello Everyone,
Ellis, here is the story of this door. Without any hesitation, this has been the most challenging project ever. It took me a while, like 3 months+ to complete this project. It is mainly built with 1/2" and 3/4" ApplePly and macassar ebony veneer, some hard maple and wenge.
Most painstaking part was the slow process of gluing so many jointed (splined/tenon & mortise) parts, probably over 2000 pieces, cut in batches to identical sizes, high precision, otherwise, 1/32" off ends up being 3/8" at the other hand. However, given its 81" height, 72" width and 6" thickness, it is indeed a moving wall and diagonal measurements for square was only off by 1/16" that lead to perfect balance and movement, which is smooth as silk.
I designed and got the hinge made by a machine shop, compression bearing at the bottom (in the floor) and regular sealed bearing for the rest.
Compression bearing was buried in a block of plywood which was buried in a space in the floor by epoxy, although it was pretty tight in a square hole in the concrete floor to begin with.
Veneering was relatively the easy part, but keeping edges undamaged, given approx. 600lbs+ weight (measured by what went in it+ 2 gallons of glue) was a challenge.
This door went to a 7000 sqft penthouse suite (3000 sqft of it is wrap around huge deck) on the 9th. floor with amazing 360* views of Victoria, BC., all the way to Port Angeles, WA.
This door has an electro-magnetic lock, which can be operated by a remote or iphone which, in fact can control the entire house.
Here are the pictures, just ask away what you need to know.
[URL=http://s233.photobucket.com/user/sfww/media/oct3postwc/IMG_1964.jpg.html]
[URL=http://s233.photobucket.com/user/sfww/media/oct3postwc/ebonydoorindex.jpg.html]
[URL=http://s233.photobucket.com/user/sfww/media/oct3postwc/s900_door_in.jpg.html]
[URL=http://s233.photobucket.com/user/sfww/media/oct3postwc/s900_door.jpg.html]http://i233.photobucket.com/albums/ee257/sfww/oct3postwc/s900_door.jpg" border="0" alt="">
AND THE HANDLE/PULL DETAIL
[URL=http://s233.photobucket.com/user/sfww/media/oct3postwc/s900_door_handle.jpg.html]
Thank you for viewing...
Chico
Re: Macassar Ebony Door (Moving Wall)
Thanks for the pix, Chico. What a commission! What a veneer job!
Hmm, questions. A million of them come to mind...Was there an architect involved in this project? Did you have any competition for the commission? How thick was the veneer? What kind of glue did you use? What was the order of work? Were all those frame and mullion elements constructed individually as boxes and then joined together somehow, and then veneered last? I can see how all those shoulders would make the door extremely rigid in every dimension, but were there also beams or other structural reinforcements? How the heck did you get it up to the 9th floor? What's the finish? Is there an actuator that opens it or is it strictly hand operated?
These will beget more questions, I'm sure.
Jim in Burlington Ont.
Jim in River Oaks, Ont.
iWall, now you're the Real App Miester buddy!! Love it!!
Take care,
Jim
Have you pictures in operation?
Gary Smyth
Just 600 lbs. The tapered bearing of the size shown seems to me to be undersized, but obviously not. Where is the pivot point? What was the support mechanism inside the wall/door? Can adjustments be made over time without disassembly? Are the openings clear or opaque and are they glass or plex? Is the lock exclusively electrical or mechanical also? What does a door/wall like that separate -- living area to living area, lobby (elevator) to interior, or interior to exterior? How did you source the veneer? Is this a giant engineered torsion box on its side?
Keith Newton
That looks great. My only concern, is that I hope you put some kind of dust shield over that bottom tapered bearing. I wouldn't manage to get that out of my shop before Sassafras and her pup-sidekick Bois-D-arc would have it loaded with dirt. Of course that will be a very clean space.
I would like to see how you handled the adjustments.
As for the opening with a smart phone app, I have that on my big shop gate, which is powered by a Sears garage door opener.
david in indy
Was the C R Mackintosh type chair shown in the photo the inspiration for the grid of the door?
Phenomenal !!!
Joe Burke
I'd love to hear answers to all of those and I could come up with more as well.
I'll start with just one though, and admit up front I hate being dense ... but ... does it swing from one side or the other or pivot in the middle? Was this addressed in an earlier thread I missed?
I'm also trying to find where 2000 pieces went.
