Help-Unisaw quit-motor burn-out?
Dick Stariha
Did i just burn out my 10" Delta Unisaw?
I was ripping some 2" foam board & it got askewed and it jammed the blade. Before I could punch the stop button, it stalled the motor. On attempted restart it only spins the blade for 2 or 3 seconds and then quits.
I checked all the 220v circuit breakers and reset them to be sure. Could half of the windings be fried? Is there a reset button somewhere?
Thanks in advanced for any suggestions or solutions.
DickS
Re: Help-Unisaw quit-motor burn-out?
Dick Coers
Better give us some motor info like hp and model number of the saw.
Bill Spievak
I don't know about the motor on your saw: however, on my Delta Planer the reset button doesn't reset until the motor has cooled down. It may be that you just need to allow the motor some time to cool.
Dick Stariha
Bill,
You're a perceptive man. I just went back out to the shop and hit the ole start button and it behaved as normal.It apparently resets after a cool down. That's a real load off my mind as I visualized a new motor in my future.
Much obliged,
DS
Jesper, Denmark
Jesper, Denmark
You'd better also find out why it did not trip the breaker on that circuit? Unless it is a high capacity circuit with wiring to match, it should have.
Bob
Bob
The reset button is sort of a circuit breaker and should trip before the home breaker. As a side note the over load protection (reset button) may be getting weak as well if its an older saw.
While tripping the motor protection "button" or the trip in the magnetic switch is not an everyday occurrence it does happen in my shop on occasion. I have 10 ga wire going to my saw. Certainly not 10 ga in the motor. I suspect motors are protected from currents well below what will trip the panel breaker. I think the panel breaker is to protect the shop wiring and that function may have little to do with the protection needed for what is hooked to it.
Bill Howatt
That is correct. The breaker in the electric panel is to protect the house wiring not the device which is why it has its own thermal protection.
Bill
Correct...
John in NM
At least in the US, circuit breakers and fuses are intended to protect the structure and it's wiring, not the equipment connected to the circuit.
Jesper, Denmark
Re: Correct understanding....
Jesper, Denmark
10 AWG wiring should have a 30 Amp breaker or fuse in the panel. The standard single phase 3 HP Unisaw motor works fine on a 20 Amp circuit. Mine is about 25 years old, and as far as I know, has no motor overload protection in either the motor or the switch on the saw.
Our wiring and suply practices are quite different from the US - There is 3 phase 380/400 volt plus a neutral brought into brought into the house and a ground rod at the house. My saw was originally on one single phase and the neutral on a standard 16 Amp three fase circuit - and frequently blew the fuse on multiple starts. This has been altered to a breaker panel (with ground fault protection on the whole installation) and a separate non-standard dedicated 20 Amp circuit.
