THE WOODRAT IS BACK!
thin saw blade
thin saw blade
thin saw blade
mark valsi
I don't know if I read it here or on another forum, but the idea to put a 7 inch fine tooth very thin saw blade on my Dewalt table saw was a great idea.
It makes cuts that are sooooo smooth, and when you are cutting small parts, it seems to be safer (not sure). I like it for cutting inlay parts and they are so smooth.
The blade I got is 5/64ths, makes nice kerfs for inlays !
Re: thin saw blade
Re: thin saw blade
Kevin French
'Safer' most likely comes from it being a shape blade that cuts everything with ease.
Re: thin saw blade
Welcome to the "club"
Most people that have actually tried this kind of blade have come to the same conclusions that you have. It is the blade that has stayed on my saw most of the time for the past several years.
It seems safer because the resistance to cutting is much less. There isn't much force acting on the wood so it is easier to keep the piece being cut under control. Additionally, the stored energy in these blades is vastly less than a typical 10" blade. The combination of these factors makes it less likely that one will loose control while cutting. It is this loss of control that leads to the blade throwing things. If they are thrown it is with much less energy. Most would conclude from these facts that they are indeed safer.
Additional benefits: they cost less, make less sawdust, saw dust is easier to capture, quieter
Limitation: depth of cut limited to about 1 5/8".
PS: I didn't invent this idea. The person that demonstrates the magnetic hold downs put me onto these blades at IWF many years ago.
Re: thin saw blade
Re: thin saw blade
Joe in a Cleveland suburb
I have dedicated blades. A rip blade, a crosscut blade, a plywood blade, combination blade....
I keep thinking about getting a new combination blade that would be used for general stuff. I often think about, and remember about, the posts Bill Tindall has made here over the years about using a small blade on your table/cabinet saw.
What blades specifically are used for this? Size, make, and so on? Do you get these blades at Lowes/Home Depot?
Any specifics?
Thanks.
Re: thin saw blade
Blades I have tried and results
Search "Stehle" in the WC archives and you will find all I have written about this topic.
Summary:
I have been using 7 1/4" 40 T ATB Industrial CMT blades for several years and there is none better. As good is the Stehle #20-15779. The Tenryu blades have not done well in my hands. They leave a rough cut.
For an 8" blade I like the Freud Avanti 40t ATB. the paint has worn off it but it has 07007091-27-08 stamped on it. I tried a 40T ATB 7-1/4" Freud of some kind at a Freud demo and like it too but no idea of the number.
In general go for an industrial quality 40T combination blade costing about $25. These blades can be sharpened once or twice for about $10.
I order from Woodworkers Supply.
Re: thin saw blade
PS
After you get used to using these blades, putting a 10" back on for some special purpose will seem terrifying.
Re: thin saw blade
Alan Sweet
Re: Blades I have tried and results
Alan Sweet
Now I have to go get a 7" blade and give it a try. Years back when I bought my Table saw, I bought a combo 10" blade and thought that was now the end. Since then I have seem to collect blades for special reasons.
This sounds great for boxes, molding and picture frames.
Thanks, I have to give it a try.
Re: thin saw blade
that's what I thought....
"This sounds great for boxes, molding and picture frames."
But since it was already on the saw I started using it for what ever I could and found it was best for most of my wood working.
