Personally I would use Shellac. A couple of wiped on 2 ~3 lb cut coats would provide better protection against moisture than either BLO or Tung oil and won't scratch quite as easy. It is probably the easiest finish in the world to touch up, just wipe on another coat and it will re-dissolve the old finish and blend right in. Even if you decide to sand out deep scratches later you can wipe on over the sanded area and it will blend right in again. I usually use a lighter cut for re-coating - like a 1 lb. I don't like to brush Shellac, I either wipe it on with a saturated rag or spray. An old cotton tee shirt works well, after it has been washed many times doesn't leave lint. I have use the new "microfiber" cloths - they also seem to work well.
When I lived up north I used to burn a lot of wood. Unless you are super gentle with your firewood that closet will get beat up in no time. Why finish it?
What it will do is resist the transfer of stain and dirt from wood to walls. It will still dent but overall it will look better, if that is a goal. Might also consider painting. Will need to re-slather now and then.
I used to live on the north shore of Boston and burned 4-6 cords/year in an airtight stove. All oak and maple logs stacked outside a year or more. Unless you are burning green wood moisture shouldn't be all that big a problem.
Why not cut a couple of air vents into the top and bottom of the door to let air circulate a bit?
