OT: AA battery charger
Stuart Johnson
My wife and I use a Roku with earphones when elliptically. It seems to burn through AA batteries rather quickly. What is a good brand of rechargeable batteries and what charger?
Re: OT: AA battery charger
Steve Mackay
I use them in my nifty digital camera, and I use it a LOT. I also have them in my remotes. I got the package of Kodak charger with Eveready bats at WalMart. VERY happy with the set-up. The whole rig was about ten bucks a few years ago. And while your getting it grab an additional pack of four bats. Then your life won't come to a stand still waiting for bats to charge.
Re: OT: AA battery charger *LINK*
Tony - Memphis
I use lots of rechargeables. This La Crosse charger is the best I have tried. I did a lot of research and this one was the top choice that I found. I think mine is actually the 1000 vs. the 700. As for cells, I have had the best luck with Sanyo eneloop cells (also from Amazon).
Tony
http://www.amazon.com/La-Crosse-Technology-Battery-Charger/dp/B000RSOV50/ref=sr_1_1?ie=UTF8&qid=1379947509&sr=8-1&keywords=la+crosse+battery+charger
I can not recommend a brand but the charger is more important than the battery. A "smart" charger will alter the current and voltage during charging for optimum battery life. Also, the charger will provide for a controlled discharge and recharge to reestablish the optimum morphology of the active stuff in the battery, likely nickel and a rare earth metal hydride in your case. It should take several hours to properly recharge in an optimally controlled fashion.
Also recharge under conditions where the battery remains cool, or at least not hot or freezing will aide long life.
R Payne
I've had the best experience using Radio Shack batteries and charger.
don't know about the charger, but
Bruce, a MN Galoot
Eneloop is a great brand of rechargeable batteries. We used them in our Sony camera until we got a Nikon with its proprietary battery. Eneloops seem to be a preferred brand among camera and electronic aficianados.
Self-discharge
Bill Howatt
I had bought lots of Nimh rechargeable batteries which are great for lots of stored energy. However, they are very poor if just sitting around because they have a high internal self-discharge rate - they loose charge doing nothing.
Various vendors have a type that using has names like "permanent" or "pre-charged" or whatever and these are the only ones I buy now. Little more money and a little less capacity for a given size but they aren't flat when you go to use them.
Bill
Kurt
There's a rechargeable battery chemistry that I'd like to see developed further - nickel/zinc. The basics have been known since Thomas Edison but apparently there were issues with a suitable electrolyte. The benefit is with devices that require higher voltage. I have a Canon camera that uses 4 AA batteries. I tried Hybrio & Eneloop NiMH batteries in it. They worked but were good for only a couple dozen shots per charge. One downside to NiMH rechargeables is they have a nominal voltage of about 1.2 volts vs. 1.55+ for Alkaline. My camera doesn't like much below 1.5 v. so it doesn't take much discharge for NiMH batteries to not function properly.
Nominal Voltage for Nickel Zinc? 1.8+. My camera will take quite a few shots including flash before voltage drops below usable. The problem I have (I only have 4 NiZn batteries) is one of the 4 cells is weak. I'm mostly using 3 NiZn and 1 NiMH. Powergenix, the company that developed the improved electrolyte seems to have transferred their resources to automotive batteries. It'd be nice to see better quality control and perhaps lower self-discharge like the Hybrio & Eneloop.
