Re: Floor Finish Question for Jason Roehl
Jason Roehl in Lafayette, IN
You pretty much can't go wrong with Bona products. That said, I consider the Mega to be a minimum--there is a lesser line sold at some of the box stores, but I can't recall the name of it offhand. To preserve what you have, do what you have to do to clean it--sweep, damp mop (mild detergents at most, nothing that leaves a residue), then rent a floor buffer (hit a tool rental place--they'll have what you need more than likely) and screen it with 150 or 180 grit screens, whatever the finish you use recommends for re-coating.
You should get about 250 s.f. out of each side of the screen, then you can use one of the used screens or some sandpaper of the same grit to get the tighter areas by hand. A buffer with dust collection hooked to a shop vac would be best, but even with that, you'll have to carefully vacuum the floor, then go over it with a damp terry cloth towel to get the dust.
To put down the finish, there's nothing like using one of these:
http://floormechanics.com/duratool_floor_coater_lightweight_12-7712.php
with one of these:
http://floormechanics.com/duratool_12_applicator_sleeve-8014.php
Pour the finish in a line near the edge of the room and "snowplow" the finish back and forth parallel to the grain as you work your way across the room. I'm sure there's a YouTube video or a thousand. If you're feeling Tim Taylor-ish, the applicators come in 18" and 24" as well (I think I saw a 30" at one point, too...).
Jason
