Helical Planer Cutter Head
Tony - Memphis
Not much posting today, so I thought I'd share this. Santa brought me a Byrd head for my DeWalt 735. I've been pleased with it except that I keep breaking inserts. I took them all out, cleaned and de-burred and re-seated them because I was getting some lines and ripples. Wondering if my no-name torque wrench is off? As I replace them, I am using less torque.
Anyway, I'm building a wall mounted desk out of tiger maple. I glued up two of the top boards and managed to get them, well, uh, non-flat. Long story, but I was trying to cheat - you can't - you need flat, straight, perpendicular etc. Anyway, I trimmed the panel just enought to fit in the planer. A little anxious since I've never planed anything so wide. Set it to just take a few thou off. I was very pleased that it came out flat and tear out free (lots of shallow passes). I had torn some grain out trying to plane the panel flat and I got passed those. So, one more board to glue on and I'll have a nice flat top with no tear out and some beautiful tiger maple (this stuff is gorgeous!). I lost a little thickness, but it won't affect the design much at all.
I still have some lines and ripples from the planer. The lines are slightly proud of the surface - maybe a few thou. I am able to clean up the lines and ripples using typical cleanup procedures (plane, scrape, sand, etc.). Didn't break any inserts last night - thank goodness! So, I do miss the glass smooth surfaces from a nice fresh set of knives (rare that mine weren't nicked a little), but I sure like running a board through with any figure and grain change I can find and seeing it come out nice and smooth with no missing chunks! I'd like to swap the jointer too, but mine is a 6" Griz and I hope to upgrade to an 8" soon. So, I'll just order one with the helical head. If I had the 8" now, I wouldn't have had the problem in the first place. Also, knives wear unevenly if you do a bunch of edges and I get edges that aren't straight! Time to take them off and work on them. I try to remember to move the fence around when edge jointing, but....
Tony
Re: Helical Planer Cutter Head
Paul Cates - Henderson, KY
Tony,
Just after Christmas several years ago I made a trip to the Byrd Tool plant to pick up a helical head, and while I was there Thomas Byrd offered to take me on a tour of the plant, and of course I accepted. Anyhow, when we stopped at the station where a couple of guys were screwing the inserts onto the heads, I mentioned that I also wanted to buy a torque wrench in case I needed to replace or adjust the inserts. Even though Byrd Tool sold a couple of different torque wrenches at the time, Mr. Byrd said I didn't need to buy one, just tighten until the head of the screw is fully seated and that's it. I haven't needed to replace or adjust any of the inserts yet, so I haven't tried it, but that's what I remember him saying.
Lars Parrington
I took all the inserts off of my 6" jointer cutterhead and then put them back on without using a torque wrench or even paying much attention to torque. i've been using it like that for a year now, and haven't had any inserts break.
i was very careful to clean everything and make sure there was no debris underneath the inserts when tightening them down. i know that can cause them to break.
Thanks!
Tony - Memphis
Hmmm, maybe I'll just get them good and snug by hand and roll on. Thanks for the info.
When I took mine out initially, I found a slight burr around the countersink hole. So, I lightly touched each seat with a diamond paddle to remove the burr. I try to make sure there is no dirt or junk on the seat when I replace the cutters.
Tony
