Question for Chest of drawers Builders
I want to build a chest for my nephew. It will be about 17 or 18" deep, that is the sides will be about that wide. I have walnut to build it from. Can someone describe the internal details for the frame that would allow for the expansion and contraction of the sides? How much would you allow for with air dried walnut? (It been acclimating in conditioned space for about a year.)
(In the past my chests had frame and panel sides and I could do that again, but I am trying to figure out if it would be simple and better to make solid wood sides.)
Re: Question for Chest of drawers Builders
I have described construction progress on numerous chests of drawers over the years. Search and you will find. But, I don't understand the need for the question. The drawer framing will be nearly identical solid side vs panel side, except for a solid side it is easier as the case side provides lateral capture of the drawer without additional framing to accomplish this function.
One point on solid sides that doesn't get much mention is grain orientation. You need to assemble the sides such that if there is any cupping the concave side will be inside. If the convex side winds up inside the drawer may bind and this is a problem that is hard to fix as it is almost impossible to plane the inside of the case side flat again once the drawer framing in installed.
Bob
Bob
You can Mill everything to 1/2" if all you have is thin material or 3/4" if you have that much. If 1/2" you can use 1/4" ply, BB, or even door skin to beef it up. If you can cut dovetails I would do that if not a simple box joint is fine. Use dados for bottom construction and 3/4" Plywood for stability in the bottom if not then I would use ribs on the underside. The top can be just glued and clamped down. Don't forget to dado for runners to hold a tray just under the top. You can buy plans on line or search sketch up for a model to use and modify it to suite your own design.
William Duffield
A good place to start is Bill Hylton's book, Illustrated Cabinetmaking. It shows several time tested construction methods.
One method is to just nail the kickers and runners to the sides. This makes it easy to remove them again in a hundred years or so when they wear and need to be repaired or replaced. The nails usually allow enough flexibility to keep the sides from splitting.
Alternately, if you are using dust frames between the drawers, the mortise and tenon joint between the rear frame rail and the side frame stiles is not glued. The rear rail and front rail are glued into dados in the case side, but the frame stiles are not. Make the side stiles just short enough that the tenon cheeks don't run into the rear rail when the sides are at their minimum expected moisture content.
asking for construction details in a couple
Dick Coers
of paragraphs is being pretty optimistic Barry. It takes 3 or 4 pages in a magazine, so I think you can find better help that way.
You are right, but I thought I already knew....
And I got enough info to get me on the right track.
Thanks to all of you.
Re: You are right, but I thought I already knew...
Joseph Mulherin, sr
try the NewYankeeWorkshop on You Tube and you might find a chest you can order plans for from them
Joseph Mulherin, sr
Barry, go to the YOUTUBE website and type in New Yankee Workshop Episodes.
Seek and click on Episode #211...chest-on-chest he makes...and also the Shaker step stool might come in handy. Plans might be available from them also for you to use.
Re: Question for Chest of drawers Builders *LINK*
Jim Dillon
Barry,
A little late to the parade, as you probably have the project done by now, but Bill Hylton's book "Chests of Drawers" has some really nice construction diagrams for both panel- and solid-sided stuff. If you are interested, go to Amazon (link below) and search the book for "Triple Dresser" or "Queen Ann Chest" (both use solid wood for the sides). You will find some nice diagrams of the interior construction that might help you visualize how he approaches things.
Jim
Chests of Drawers
Ordered this.
Joe in a Cleveland suburb
Thanks for pointing out this book.
Looks interesting. I just ordered it.
Looks like it will be a good reference for ideas and so on.
Thanks.
Re: Ordered this.
Jim Dillon
Joe,
You're welcome. I think you will enjoy the clear writing and equally clear diagrams that Mr. Hylton provides. After my previous post, I spent an enjoyable hour or so rereading portions of his book and refreshing my memory about various ways to handle carcass construction where drawers are involved. The Hylton book that Mr. Duffield mentioned must be very similar in nature.
Edit: A number of years ago I built the mortising jig described on pages 124-5, and it has been a real workhorse that I have found to be very versatile.
Jim
Re: Ordered this.
William Duffield
I'm going to guess that the book I recommended, Illustrated Cabinetmaking, doesn't go into as much detail about chest construction, because it also covers many, many other furniture forms. Most of its illustration and teaching techniques consist of exploded drawings, with some written description of construction details. If you need measured drawings, cut list, and cutting diagrams, it is not the book for you. You have to decide for yourself what you want to build, how big you want it to be, what you want to build it out of, and how you want to decorate it, and Bill will show you how to build it efficiently, and so it won't come apart.
Chest of drawer framing-few options survived
One hardly needs a book for this task if you have access to any old furniture that has survived. Just look inside it. You will find only two common options. Dovetail a top and bottom into the chest sides. Then either dovetail or M&T the drawer dividers into the case sides. From what I see in antique furniture dovetailed dividers don't ever pull out from the sides. Tenoned rails eventually do a little bit. M&T runners between the dividers. That's it. The rest is decoration.
"Dust panels" are vestigial. Their true function was to prevent access between locked drawers should one drawer be removed. Nobody builds drawers with functional key holes now days so it is silly to keep the dust panels that made locked drawers secure. They just add weight and complexity for no benefit.
Dust panels
Gary Smyth
You make a good point. I never thought of dust panels as a security function. Aside from the collection of ground wood dust that was created by the action of opening and closing the drawer on the frame - thus preventing the dross from entering the drawer and the contents below. I was taught/told that they helped limit racking/warping before air conditioning stabilized humidity. They had the added advantage, if installled, to discourage bugs and critters. Bay leaves or other natural deterrents/deodorizers could be placed under the drawers and not on the contents that might discolor. Locked in dust panels make sense as they will discourage theft, but do all old dust paneled drawer cabinets have locks? I don't know. I shall look around, but fine old furniture is scarce here. Interesting point though.
My kids needed dust panels
Dick Coers
They use drawers like garbage compactors. They always had the idea that one more sweater could fit. So the sweater goes in, they jamb it down as they close the drawer. Without dust panels, the sweater swells back up inside the chest of drawers and then scrapes it's way back out. Dust panels limit that sweater expansion.
Re: Dust panels
Paul Cates - Henderson, KY
Interesting discussion. "But do all old dust paneled drawer cabinets have locks?" Or worded the opposite way, do all chests of drawers with locks have dust panels? This one doesn't, and from what I can see it never did, which always seemed odd to me since it has locks.
Sgian Dubh
Barry, here are a couple of images (sketches) I have to hand that outline typical construction options for that cabinet type-- they aren't the only options of course. With walnut being a pretty stable wood I'd allow something like a 2.5- 3.5 mm gap between the rear end of the runner/kicker and the inside edge of the rear rail. Dustboards are optional and fit into a groove worked on the inside edge of the frame parts-- obviously if there's no dustboard you don't run a groove. Note that the tenon on the front of the runner/kicker is only a stub tenon, and that the runner/kicker is not glued into the shallow housing (dado) worked in the carcass side.
You may find that working a rebate in the back edge of the two sides and the top of the carcase is a better option than the groove shown in the sketches. If you use a rebate all you have to do is drop the back in place and screw it down and, if the back is large, e.g., ~1200- 1500+ mm tall, this is often easier than trying to slide the large back up into the groove from the bottom. Slainte.
questions
What purpose does the dado in the case side for the runner serve, given that this runner is already fixed in position by a tenon and dowel. And, why a dowel on one end and a tenon on the other?
Re: questions
Sgian Dubh
"What purpose does the dado in the case side for the runner serve, given that this runner is already fixed in position by a tenon and dowel."
It reduces flexing of the runner/kicker if you've got a heavy drawer, particularly when it's 2/3 or so extended. It's also optional.
"And, why a dowel on one end and a tenon on the other?"
Speed of construction mostly, but again it's optional, and probably best suited for when the runner/kicker is housed into the carcase side, because the housing provides the bulk of the locking against pivoting for the runner/kicker. Also, you can bore a shallow hole into the rear rail, thus avoiding disrupting the grain too much and weakening the tenon, and glue the dowel(s) in there. Then you can bore deeper holes in the rear end of runner/kicker and fit the dowels dry to allow for side shrinkage and expansion-- there's no danger then of the dowel slipping out of the bored holes, but a stub tenon into the rear rail might slip out of the shallow mortice or dustboard groove. Slainte.
