Polystyrene Core Torsion Box
don stephan
I'll be making several torsion boxes and would like to use the pink polystyrene insulating board made by Owens Corning for the core, with a wood frame around it. The top and bottom panels will be baltic birch plywood.
A couple tests with glues on the polystyrene didn't have very much adhesion after curing. I tried urea formaldehyde and Titebond I. A second test before I left tonight was again with urea formaldehyde, but I roughed the surface of the polystyrene with 80 grit sandpaper.
Has anyone had success gluing polystyrene, and if so with what adhesive? My tests were with bar clamps but the torsion boxes will be clamped in the vacuum bag.
Re: Polystyrene Core Torsion Box
Re: Polystyrene Core Torsion Box *LINK*
Tom Dunlap
There is an off-shoot of the tear-drop trailer cult made up of people who are using foam as the structural form for trailers and campers.
Read more here:
Foamies
Dick Coers
Are you using the polystyrene for insulation properties? Otherwise I would think thin wood strips inside would be stronger and barely any more weight. I am skeptical that the polystyrene will be flat enough to provide full contact with the skin and then flush with the frame. Did you try Gorilla foaming glue? We use that at work on rigid urethane foam and it's as strong as the parent material.
My choice would be thickened epoxy,
Keith Newton
It doesn't have any solvents to cause issues, and if you give it a skiff sanding, should adhere fine. By thickening, you give it bridging capacity, and will be stronger than the foam. I like to add enough silica to thicken it about like heavy latex paint, so it can be applied with a roller.
Any advice is more relevant when we know what the end use will be. For all I know you may be choosing the wrong core for what you are wanting to achieve, but I or nobody else will know until you have squyep the pooch. I guess you know there are sources that sell other densities besides the pink?
john Veerkamp
Dap and some others make adhesive specifically for your foam. look at big box stores that carry foundation insulation. just a few bucks per tube.
Jesper, Denmark
Re: Find another core material.....
Jesper, Denmark
The expanded polystyrene has so little physical strength, that even if you do find a glue, the polystyrene itself will break under very low shear or tension. Balsa, PU foam, Divinycell etc. are OK.
Rick W
I made some torsion box panels years ago. They had white polystyrene cores and 1/8" lauan plywood skins.
Tha panels had an outer frame of 3/4" X 1-1/2" poplar. There were several horizontal ribs of the same size poplar, and 1-1/2" thick polystyrene pieces between the ribs. The 1/8" lauan ply skins were attached with water-based contact cement, 3M Fastbond 30.I applied two coats of the contact cement to each face, and pressed them together in a vacuum bag press.
The panels held together well. In fact I still have my test piece, still holding together after several years.
Hope this helps, and good luck with your project.
Rick W
John McGaw
Actually, the sort of rigid closed-cell polystyrene insulation board sold over here is very strong in compression and that is really all that is needed in this application (assuming that one can find a good glue to attach the skins). I can stand on rigid poly insulation and leave only the shallowest of dents and that is a much more severe test than acting as a spacer inside a shelf. I have large scraps of the stuff here that I've been using for years as sitting/kneeling pads and they've seen a hard life but they last for a very long time. Granted that some of that beautiful German PVC foam so loved by yacht builders would be even better but sometimes cost is the overriding measure.
Yonak
I tend to disagree, Jesper. I believe expanded polystyrene, properly produced, has pretty good integral strength and good shear properties when bonded to a shell. The key is to be sure the bond will hold fast. How about non-petroleum based construction adhesive ? A tube I have says it's good for foam board and water clean-up.
J Baird sw chicago burbs
Loctite high performance spray adhesive,follow directions, for foam and wood works very well. I had some 8" foam that i sandwiched between 3/8" ply that i use to set my garden tractor on when i am changing blades. I also blocked up the rear end of son in laws small suv with the same blocks. john b. SW Chicago burbs.
don stephan
This particular application is panels to lay over a billiards table to serve as a dining table a few times a year. And yes, large lazy susans will be needed because diners wouldn't be able to reach the middle. Cleats under the panels will just touch the billiards table surface, so the purpose of the foam is mainly to avoid a hollow sound and stiffen the 1/4" baltic birch skin. If the panels had to support weight I'd use internal ribs to stiffen.
A well clamped test with Titebond I for 24 hours showed less adhesion between pieces of foam than I had hoped, but probably more than enough. On another test last night I roughened the surfaces of two pieces of foam with 80 grit, then applied urea formaldehyde glue to one surface and clamped well. After 24 hours this pair was harder to break apart, and on perhaps 15% of the surface area the glue bond was stronger than the foam.
I have no doubt that some of the specialty construction adhesives will make a very strong bond, but the higher viscosity is a concern - not sure a vacuum bag could fully level out construction adhesive.
The long working time of urea formaldehyde is a significant advantage, so I will likely use it along with roughing the surfaces of the foam core. Thanks for all the replies.
