ADVERTISE HERE - FREE TRIAL
Know where I can find?
Gary Smyth
Stryofoam paint pad. A bit over 12" long by 2" wide. Pic is optical illusion. Never found additional long ones. Had 2, pictured is last one. Big boxes don't carry. Local paint store tells me it doesn't exist. SOMEBODY makes these. Shur-line and Roller lite says not theirs. Didn't see on ebay and Google turned up empty for me. Anyone have a source?
Re: Know where I can find?
Paul Blackwell
Try Amazon and do a search for styrofoam paint pads.
One of my 1st searches - no luck
Kind of looks like the green stripe may be a "hook and loop" fastener - could this be what you are looking for? http://www.midlandhardware.com/135765.html#.UjESnj_CngE
Yonak
Gary, how do you use it ? Is it like a silk screen squeegee ?
Finish application
Gary Smyth
These are sometimes called touch up, paint edge, or trim pads. With paint they are used to paint to right angles like ceilings. Load em up and drag it at the edge. It flows the paint using less skill than required by a cutting brush. They typically are about $2.00 each, and are throw away. Simply made, they have a styrofoam portion that is a handle, a 1/4" usually green foam backing, and a 1/4" nylon(?) short nap "brush" all glued together. I use them for finishing. They hold a lot of material, do not shed, minimize bubbles, and leave few tell tale "brush" strokes. Because they are wide and clean, I use them with shellac so I can do flat work in one pass as the shellac and alcohol evaporates so quickly in heat of summer. They also work great with thinned poly for the insides and outside of unassembled drawers.
Pics show the long brush I'm looking fors nap when new, and (in the plastic bag) a smaller version loaded with tinted shellac. The wood is a plain Ikea plywood box where the brush floods the board in a single drag as there are no "go overs" with shellac.
Right item , emailed about size.
Andy Halterman: A pedaling fool
Padco makes a 10" applicator that may work for you.
http://www.padco.com/default.cfm?PID=1.1.17
We use the 8" version all the time for applying water based floor finish. I've had very good luck with their stuff.
Andy Halterman
Breaking my fast on honeydew in Hendersonville, NC
