Macabre Thought Re: Wood - and bones?
charlie belden
We all work /play with dead stuff - wood - and sort of like Dr. Frankenstien, we attempt to give it a new life. We make it into furniture, spoons, boxes, bowls, plates, platters, cutting boards - and maybe a coffin. Were we to not intervene, it would return to the soil - or be burned - Ashes To Ashes, Dust To Dust.
So I've got this piece of claro walnut burl saved from a tree that was cut down, though not in its prime of life, the thick bark still on it, but still not able to hide what was below. The chainsawn face showed all sorts of interesting figure. Having sat outside for three or four years, the bark was fairly easy to remove, revealing ripples and bumps and conical spikes.
Initially I focused on the cut face, thinking where the best bowl or hollow form might lurk.
Then I flipped it over and began wire brushing up what was under the bark. A bit of scraping, a bit of brushing, a little soda blasting, some more scraping, brushing and soda blasting - and the realization that NOTHING I could turn could possibly be as interesting as what this tree had created in its lifetime. The best choice, at least for me, is to do what I can to bring out the best of this trees mortal remains - or at least this piece of it.
Having wet the surface I've got now - with alcohol I've got a ways to go - but promises some real beauty. If I do it right, anyone who sees the end result will probably never be able to look at a living tree they take for granted - and not imagine what beauty might be just below the surface . . . And once you begin looking for, or imagining hidden beauty - in a tree - that might extend to other living things
Which promted a macabre thought. When I die, could something useful and perhaps aesthetically pleasing, in the right hands, be repurposed - beads, maybe a few crotchet hooks or knitting needles, maybe a delicate finial for a small piece, a small flute, a carved and pierced animal form - or perhaps of a stand of trees.
Aside from organ donating, would you want to be "repurposed", and if so, as what?
