bowling alley
bowling alley
bowling alley
rob storch
working with bowling alley and wanted to know if there is an easy and safe method to make table tops with out taring it apart and reglueing and screwing it ..???
Re: bowling alley
There Be Steel
in them dead trees!
If you haven't found it already, you need to watch for the bolts that are used for reinforcement of the glue-ups. A metal detector can be your best friend when working with "alley" material. IIRC, some of of the steel is "through" side-to-side, but some may be buried and not apparent from looking at the edges.
Re: bowling alley
Re: bowling alley
Ralph Lipeles
A while back I tried making a table top from a section of bowling alley. Although the strips were all nailed to each other, the cut out 6' section that I had was very flimsy. When I lifted it, it would arch quite a bit. The bottom was not flat enough for cross strips and I finally gave up on it.
With the woodworking experience that I have gained since, If I were to try again I would disassemble the entire section and hand scrape (to remove dripped varnish and dirt) and then surface plane each strip. Initially the strips should be cut about 5" over in length to accommodate the planer snipe. If the strips are not distorted they can be just glued and clapmped. If the finished surface is not good 2 guide strips and a router sled will be needed to create a flat surface.
Ralph Lipeles
Re: bowling alley
Re: bowling alley
Howard Acheson
Every bowling alley I have seen, was held to together with a gazillion nails. They were not very useful for things like work bench.
Re: bowling alley
Base Support
I purchased some sections of bowling alley years ago. As others have said, lots of nails. What I did was cut an alley section to the size I needed. I flipped it and clamped it tightly. I then used some 3/4" plywood and screwed it (all over) to the bottom of the lane section. That kept it together and from bending at the joints.
Next, I laid the sections on my driveway and ran a floor sander on them to remove the thick layer of poly. Then I created banding around them to finish the edges. The banding on the ends needs to be able to work with the expansion/contraction of the slabs BTW.
Here is a workbench I made with bowling alley for my own shop. Good luck!
Re: bowling alley
most are not glued just nailed.....
Dick Coers
and the nails are hardened to be able to drive through hard maple.
