solar panel calculations
Joseph Mulherin, sr
I am planning on making my own panels, but am not receiving proper answers to my website searches.
Panels will be 3'x5', using 3"x6" cells. All I receive are directions to companies to install units. I have the plans I want to make for my roof, but cannot get the wattage I want or need from the calculations of these panels sizes. My monthly house wattage is about 4800kw per month....think I should plan on about at least 6000 watts. Please help, thanks, Joe
Re: solar panel calculations
John McGaw
Can you clarify? From what I read you want to know the calculations for producing 6kW of power. All that would involves dividing the amount of power one cell produces into 6,000. i.e. if one cell puts out 12W then you would need 500 of them arranged in a series-parallel array depending on what output voltage you desire. The number of series-connected cells would depend on the single-cell voltage divided into the desired overall voltage. If I were doing this I'd be sure to add a low-forward-voltage isolation diode to the end of each series-connected string making sure that it is capable of handling the string's current + a suitable safety factor.
Seriously though, why do you want to put yourself through all of this? Solar panels are pretty much a commodity item and buying one ready-made will probably be cheaper and will certainly be easier than trying to build one. Not to mention the lack of a warranty on a homebrew panel. Don't forget to check on any possible insurance liabilities too -- if your building burns because a homemade panel shorts out your insurance provider may look askance at paying up while with a commercial panel with safety certification they would have less wiggle room.
Jason in OC
I don't understand what your question is. You want to build up solar panels from individual 3"x6" cells? You're trying to size a system using panels of specific dimensions? In any case there is a lot of information including examples of system sizing spreadsheets and component vendors at this site:
http://www.homepower.com/
You'll need to spend some time surfing around in there. It is a DIY-focused magazine for renewable energy.
Brian from Monument
The other part of the equation should be how are you going to connect the panels to your house and how is the house going to use the power. Will you store the produced energy in batteries ?
Will you attempt to power 110 circuits or just 6/12 or 24 volt lighting?
A installation company will know how to do all the variations on this theme and where to get the parts.
As others have said most of the stuff used in this endeavour are near commodity status at this point in time.
Recently I have had installed in my motor home a solar array.
It will charge the "house" batteries which are "deep cycle" and not the kind used in the chassis or ignition/vehicle type of batteries. While they look similar they are very different.
I also have a inverter to convert batter power into 110.
But the motor home is a smaller scale project then a whole house.
But I still paid a pro to do it.
So far the panels have kept the power in the batteries up to snuff.
Survivorman had a show about living off the grid.
Very interesting, used solar and wind power.
Brian from Monument
There is a guy who I stumbled across that has something he claims is instructions for making solar panels.
He charges for it.
Try this email.
frank@power4patriots.com
Joseph Mulherin, sr
I agree with your thinking, John. I did some calculations myself and the one design I came up with would not provide the output I wanted, so I am going to contact a company...renovasolar.com...and see what their program entails. I understand you would lease the equipment and pay a monthly fee....which would be considerably less than my regular monthly charges to the electric company.
Not Quite a Scam
but close.
The "plans" he pushes, while advertising "the Power Companies Hate This" and similar tag lines with a picture of a magnetic motor or some magic box with switches, dials, and cordless phone antennas stuck on it, are for a low output solar and, "reportedly", will charge your cell phone and not much else.
You can google several analysis of what he offers. Pass the Patriot Dude by.
Re: Not Quite a Scam
Brian from Monument
That is why I used the word "claim".
And did not assert that I knew he was on the complete level.
Kneale Brownson
calculations are important
Kneale Brownson
You want someone to figure out for you, based upon your power use history and your plans for additional uses, how much output you need. The power company really doesn't want to buy from you and you get into all sorts of tax questions if you "make money" off your solar panels. There are companies out there that will figure it out, provide the panels and installation and collect the "reduced" monthly fee while selling your roof's output to the power company. Some of them turn over the equipment to you after 15 or 20 years, by which time you probably will need to replace the panels, and some will not. Shop your area to get the most favorable deals. I have neighbors who paid up front for the service but no longer pay anything to anybody unless their electric use increases significantly. I have others who paid nothing up front but still pay their averaged monthly electric bill. Get what suits your situation. The advice about your insurance company covering a loss with a home-made system is correct. You have to read the fine print inside the fine print to determine how things you might do--like using a different manufacturer's breaker in a breaker box--that can impact a settlement.
Re: calculations are important
Joseph Mulherin, sr
I have decided to NOT attempt to make and use my own panels. shall contact renoasolar ad get their programs of leasing.
