turning on a wood lathe
Jack Putnam
When you are turning on a wood lathe and the object you are shaping what is the best way to cut the excess ends off so that both finished ends are flat that when it stands up there is no wobble to it. I have tried a band saw and it does not cut that straight it still has to be sanded to to make it flat. I even tried using a sander but I have to be careful not to sand it at an angle. Thanks for any help.
