Have a question? Ask Woody!
Upholstery Staple Gun advice needed Please
Anybody doing upholstery? Do you use an air stapler? Any advice on which one to buy or not buy? How much air pressure does it need? What length staples?
Is there a slick way to remove the old staples? What other tools are useful?
Re: Upholstery Staple Gun advice needed Please
andrew nistock
Barry, I don't do upholstery but I do use a upholstery staple gun when I attach gripper strips to rug hooking frames that I make. I use a porter cable US58 with 1/2 inch staples. I drive the ataples into ash frames and have driven over 10,000 staples in the last year with no problems. Just a little oil to lube the gun is all that has been necessary. would highly recommend this unit. Needs about 90psi if I remember correctly to operate. Tried an electric staple gun which was a total failure even in softwood. I use needle nose pliers to take out staples that bend if I hit a hard spot in the lumber.
Jim Toews
Barry,
I had to do some upholstery for a project a couple of years ago. I have absolutely no experience of training in this. But (there is always a 'but'!) I stumbled across this website and was able to learn enough to successfully complete the project. I purchased the upholstery stapler and staples he recommended and am completely satisfied with them. 90 psi sounds about right, if memory serves. (I am in no way associated with this company, just a satisfied customer.)
Jim
http://www.diyupholsterysupply.com/introduction.html
Thomas S Stockton
Barry
I have the cheapest stapler Home Depot had works great takes senco brand staples and has never given me any problems. Upholstery supply places should have staple removers they look like a bent screwdriver with a v notch in the end, I use awl which works well.
Don't use really long staples they are a pain to remove 1/2 or 3/8 are fine
don't use the narrow crown construction staples they blow through stuff and are even worse to remove.
I run my stapler at line pressure.
I'm sure a staple gun from harbor freight would probably work fine also.
A webbing stretcher is helpful, but I use a vice grips to pull the webbing tight.
look in the articles section I did one on upholstering a slip seat
Tom
Ditto on the Porter Cable US58
Tim Greif - West of Chicago
LOML is currently in the process of reupholstering some dining chairs. I bought her the PC gun a few years ago when we got into upholstering. The gun uses 3/8" crown, 22 ga. staples.
This gun is very reliable. Initially, we had some issues with staple misfires. This turned out to be caused by low operating pressure. We found that running the gun with at least 80 psi eliminates the misfire issue. We generally use staples that are 3/8" long or shorter. We probably use 1/4" and 5/16" long staples the most, since they're easier to remove if needed.
Good luck.
Jason Roehl in Lafayette, IN
Two things:
Wide crown. (Narrow crown are VERY difficult to remove if you shoot an errant one or re-do it.)
Oil-less. If it's oiled, that oil is in the exhaust...
I'd have several hand tools on hand for removal: end nips, channel locks and needle-nose pliers. Find what works best for you and use that the most, but occasionally you may still need one of the others.
Jason
