Graphite canvas for sander platen
Keith Newton
This morning I was sanding some oak lumber too large to go on my stroke sander, using my old Rockwell 503 belt sander. The platen, not it's first is getting worn, causing it to buckle, which sands a little deeper on that spot.
These are great sanders, and I really want to keep it working, so I started searching for parts, and was coming up empty. Before I realized I should be searching for PC 503, I was thinking maybe any brand might be worth a try. Then it dawned on me that I have a pretty good supply of graphite canvas on hand, and ought to give that a try.
I'm sure it would work, but I did find and ordered the new part, which wasn't much, and added new brushes and a new bag, so It ought to be good as new in a few weeks.
I just thought I might mention the graphite, since probably a lot of the members of this forum might not know about it, or how it might be used. It is basically a heavy canvas 6" wide, although other options are probably available, with one side heavily coated with graphite, which is really slick, and it can be wrapped around shaped or flat wooden platens on the backside of the belt.
The platen for my stroke sander was the first place I used it, but then I got an old edge sander from a industrial shop auction which rather than an idler wheel on the end opposite the motor and drive wheel, had a graphite cover round wooden nose. I used it like it came probably 15 years, before needing to sand a lot of parts with a lot smaller radius. Rather than just doing a small semi-circle end, I had a full size template leaning in a corner from a sailboat keel re-build, which was more of a parabolic curve. I just traced that shape on a dry piece of cedar fire-wood, tacked on a new canvas, and have loved it ever since.
I know some of you think a lot of your spindle sanders, but I'm sure you probably don't need to be told that a short length of abrasive generates a lot of heat, and if it doesn't have time to cool before it comes back into contact with the wood, the heat builds so high that it melts resins within the wood which otherwise would be solid. The liquid or semi-liquid then loads the abrasive, even if it isn't dull or worn out. Being able to send a long belt around a small shape prevents this problem.
However, a nice thing about my long elliptical nose, is that not only can I get into tight radii, it is a gradual transition into a more gentle curve, which is really nice on long concave curves, or changing curves. Since I'm free-handing, I can maintain contact with the portion of my platen which matches the inside curve of the arc being sanded, which makes it easy to sand to the fine line, without ending up with other little unintended concave spots where I might have lingered, hiccuped, or blinked wrong. I'm sure you all know what I mean, if you have tried to sand a long arc with the nose of your portable sanders.
On that note, I do a lot of curved work, and sometime the work is too large and unweilding to manage on the stationary tools. So another little trick I use for inside curves, is to bandsaw a little arc with a flat side, chord actually, then slip it under the platen, and cork of a hand-held sander. This is easy to do, and for those long slight inside curves, makes it easy to hit a fair curve.
Even though I have not done this yet, I have considered adding a considerable addition in place of the metal platen on my 21" sander, while using a belt from my 24" to manage some speciality needs. Even if you don't have an edge sander or are willing to modify the one you have with a idler wheel, this is another way to create a contour for a special job just using a portable sander that you already have.
