Is there a US source for antiluce fasteners? *LINK*
Tom Dunlap
I've seen these used but I have no clue where to purchase them. They seem common in the UK but NOT in the US.
Maybe there's a different name for them???
Tom
Antiluce latch
Re: Is there a US source for antiluce fasteners? *LINK*
John McGaw
You could do what I do when something isn't available in the US (like books that won't be released here until six months after they show up in the UK) -- order it from over there. It has proven to be relatively cheap and easy for many things. I'll admit that books and hardware aren't the same but it might be worth a look.
Antiluce at amazon.co.uk
Tom Dunlap
The shrinking of our world to the distance from fingertips to keyboards is an amazing thing! To think that the voyage from England to Australia in the early 1800's took six plus months...whew!
If I do use these it looks like its going to be a UK purchase. I really try to buy as locally as I can. Shipping stuff around the globe is an interesting proposition.
Something as simple as this pins surely must be sold in the US. McMaster-Carr doesn't sell them under that name. I've googled and searched for other vendors in the US and come up empty handed.
If I had a milling machine or a machinist that would trade machine time for me doing some treework I'd be set. Again...I come up empty handed :(
Tom
How do you plan to use these things?
I confess that I've never seen or used such items, but now I'm interested in what they are for. It's probably obvious, but I'm drawing a blank.
Re: How do you plan to use these things?
John McGaw
Acts as some sort of draw wedge from what I understand but I, like you, have never actually seen one in use.
Answer to what are they used for...
Lloyd in Mississauga
From...
http://www.albert-jagger.co.uk/portals/0/010_a1_antiluce.pdf
The photo in the to right shows them in use, sort of...
Designed originally for securing lorry side and tailboards, its use has been extended to pallets, transit crates, lockers and a wide range of machinery.
Essentially, a captive cotter which dispenses with loose cotters and chains. It is secure, robust and simplicity itself to use. It eliminates lost cotters, broken chains and damaged paintwork. It is a complete fastener in itself and its one piece construction saves time in fitting compared with the two parts of a peg and cotter fastening.
Lloyd
Uses *LINK*
Tom Dunlap
What Lloyd said :)
Think of an application where a panel needs to be secured and a stud with a cotter or spring pin is use. antiluce pins work great because the tapered steps in the slot keep the panels from rattling. The best part! No lost cotter pins! They're stout too! I;ve seen them used in many applications when I've been in the UK and they've stood up to abuse.
The drawback is that the stud can snag on things or be bumped and it hurts!
You might be able to see my ToyBox project from the link. There is a plan for some underbody boxes as well as roof racks where these clips would work nicely.
Tom
ToyBox
Re: Uses
Dave huber
I've seen similar on portable scaffolds that are required for overhead work in Chicago, where I live. These are the walkway coverings used to protect pedestrians from dropped tools and materials while work continues above.
I'll take a better look next time.
I hope this lead helps.
They are clever
Re: Closest I've Seen
Tom Dunlap
Hi Jason,
Yup...those are similar, and available in US.
They don't have the tapered slot in the toggle which locks down the panel.
If I can find a machinist who would trade their shop time for me doing some treework it would be a go!
Rick L
Re: You are making this  complicated
Rick L
Appears to a UK, AU, NZ type of hardware. Just buy them from there. I bought a laptop cover from Australia and it came in a week and didn't cost anymore for shipping than having come from acoss the country. In the old days by the time you got a bank check in the proper currency and with shipping it would take months to order something simple.
TED
Warren Fastenings South Inc.
North Charleston SC 29406
843-554-1322
We are a stocking Distributor of Antiluce Fasteners.
