I usually just use my dovetail bit when cutting sliding dovetails.
How many of y'all use a straight bit to cut out some of the material before? I've got a 1/4" straight bit and another router - so it really wouldn't be a problem.
I haven't had any trouble doing it with just the dovetail bit - but I was sort of wondering if it would be better.
There are a couple of good reasons. The main one, is that you can maintain better tolerances. When I have lots to cut, I use a dado blade on the TS sled, which would cut faster than another router.
Because the dovetail bit slants upward at the face, it tends to lift the grain, leaving a slight ridge, and the chips tend to clog the slot, which raises the following base of the router base, or if on a router table, the wood rides up on this. Either way, riding up, makes the depth less. Cleaning the slot, and making another pass won't work, because the top will be wider also.
then there is the little matter of the nature of dovetail bits having a tiny waist, even when on 1/2" shanks, but especially with 1/4" shank bit, deflection will be greater the harder the cutter has to work.
