What did I do to my table saw?
David Hay Denver
This evening I was tilting the blade of my contractor table saw to 45 degrees. I forgot to move the outfeed table and the motor pushed up against the table. I kept turning the wheel and at some point I heard a pop. Then I noticed something was wrong...the blade was rubbing against the edge of the table saw insert.
I was hoping that it was just the trunions out of alignment from the table, but the attached picture shows that there's something more serious out of alignment.
If you look at the splitter receiver, you'll see that it is over as far as it it will go. Obviously it needs to move about another 1/8 inch or so. However, before this incident, it was in alignment with the blade.
So what did I knock out of alignment? More importantly, how do I fix it?
Thanks for any suggestions!
David
Re: What did I do to my table saw?
Brian from Monument
Check alignment of blade vs splitter vs miter slots.
Just to confirm that the blade/splitter are out.
I agree with above, plus
Keith Newton
You might want to share the BRAND and model of TS, since that might help.
in photography, there is an inherent flaw, I guess, called converging lines, due to lens shape, that can make things look off, even when they are not.
David Hay Denver
I have checked the blade, miter slot, and splitter alignment. The problem is that I can't move the splitter over any further in order to align it with the blade. The photo is a pretty good representation of what I see and can measure.
Something else has moved out of alignment and I haven't been able to figure out what it is or how to correct it. Possibly something with the trunion bars?
Also, this is a Delta contractors saw...probably 15 years old at this point, if that helps any.
Thanks!
David
Howard Acheson
You have probably pushed your tie bars out of alignment. Here is something that should help you get it back it shape.
There is a significant area of alignment that is not detailed in most magazine tune-up articles. It is ensuring that the trunnion bars are exactly in the same plane. Proper adjustment affects bevel cuts and is indicated when there burning when making bevel cuts. Here are the corrective steps that were at one time posted on the Delta website.
First go through the alignment process following the steps in the attachment below.
To check whether the trunnions need to be adjusted, tilt your blade fully to the 45 degree position until you get to the 45 degree stop. Then crank the blade back to the 90 degree upright position. Now again check the parallelism of the blade to the miter slot. If the blade is still parallel to the miter slot, declare victory. If not, follow the process below from Delta to adjust them. The process is the same for all Contractor Saws or Hybrids that have the trunnion assembly hanging from the table.
1. Remove the saw blade being sure it was at it fullest height.
2. Place a flat plate (or similar flat object) on top of the two tie-bars. (The size of the plate should be at least 6" by 8", and the flatter the better. A pane of glass works well.) Depress one corner of the plate and if it rocks, the tie-bars are not parallel. This must be corrected as it will affect the alignment of the blade.
3. Loosen the tie-bar locknuts located at the rear of the saw.
4. Grasp the motor bracket and move it left and/or right. Check the rocking of the flat plate and when it can no longer rock, the tie-bars are parallel...re-tighten the locknuts.
5. Remove the flat plate and re-install the sawblade.
6. Again perform the parallelism alignment process.
7. Before tightening the rear trunnion bolts, push forward on the rear trunnion bracket to allow the undercarriage to snugly fit between the two trunnions.
Now go through the following alignment process.
Here is the low tech, low cost way to align a tablesaw that I learned maybe forty years ago and use to teach to my students.
Make 3/4 x 3/4 x 12" hardwood stick. Drill a hole somewhat centered in one end and insert a brass #8 x 1" round head fine thread machine screw about half way. UNPLUG THE SAW. Raise the blade completely up. Clamp this board in your miter gauge (if you determine that there is some slop in your slot to miter gauge, use a playing card to take up the slop) so the screw head just about touches the blade at the front. Now rotate the blade by hand and determine which tooth is the closest. Adjust the screw in or out until it just touches this tooth. Mark this tooth. Rotate the blade so the tooth is now at the back of the table and move the miter gauge/stick assembly to the back and see if it touches the marked tooth to the same extent. If it doesn't, adjust the trunnion (if a contractor saw) or the tabletop (if a cabinet saw) until it does.
For a contractor saw, first use a small c-clamp on the rear trunnion and cradle to keep the assembly from moving. Then loosen the two rear trunnion bolts and one front trunnion bolt. Slightly loosen the other front trunnion bolt and use a stick to tap the trunnion until the blade and screw lightly touch. The blade does not move directly around the center so you will need to repeatedly go back to the front of the blade, readjust the screw, and then again measure the back. Be sure to check after tightening the trunnion as the trunnion frequently moves when being tightened.
For cabinet saws, loosen the bolts that hold the tabletop and tap one corner until things come into alignment.
The same adjustment gauge can be used to set the fence parallel to the miter slot. Slide the miter gauge to the front of the table and move the fence over to the screw head and insert a playing card between the screw head and the fence just so you can move the card as it touches both the fence and the screw head. Now move the miter gauge to the back of the table and see if you have the same feel when you insert the card. I like my fence absolutely parallel--if you want to have a slight opening to the fence, you can easily estimate the opening by adding a thickness of paper to the card.
I always show my students with a dial gauge that their adjustments are within .001 - .002.
You can also use the same gauge to measure blade runout by using a $5.00 feeler gauge.
Finally, after you are satisfied with the above adjustments, check the position of the splitter to make sure it is exactly in line with the blade.
Bottom line, there is no need to spend more than the $0.05 for the brass screw.
Re: That was it!
David Hay Denver
Thanks, Howard! This is exactly what I needed!
The problem was, indeed, the trunnion tie bars. Once those were re-aligned, everything else lined up just fine. In fact, I'm not sure the tie bars were *ever* aligned correctly. I don't remember having as much play with the splitter adjustment when I originally installed it.
I'm definitely printing these instructions out and putting them with my table saw instruction manual. (they should have been in there to begin with!)
David
Re: That was it!
William Duffield
Before you call the job "done" go fix your outfeed table so it won't happen again. You'll probably need some sort of a cutout in the table, but probably not all the way through.
Good idea, and to that end,
Keith Newton
Back when my contractors was my only TS, I needed more power, so moved up to a 2hp open frame motor. I found that mounting the pulley so the belt was as close to the motor as it could go, and then shoving the motor to the max toward that side reduced the butt end height when tilted. And it seems like I may have gone to a longer belt, so it hung lower.
Besides that, on all three of my saws, I have a gap between the saw top, and catch table. I like the front end of the table to be about 1/4" lower than the TS, but a straight line from the saw top back hits half way down the catch table.
Re: Good idea, and to that end,
David Hay Denver
Thanks for the idea, Keith! I moved the pulley closer to the motor and moved the motor over to keep the pulleys in line. That got me another 7/16" of space between the top of the table and the top of the motor at 45 degrees.
I also spent part of this afternoon routing a recess in the bottom of my outfeed table (MDF is seriously messy stuff) to accommodate the motor.
Hopefully I won't have a repeat of this. I'd rather be making stuff than adjusting my tools!
Thanks for everyone's help and suggestions.
David
