Blue Holly
Blue Holly
Blue Holly
Doug Reynolds in Seattle
I have a chance to get some pretty big holly, about 8-10 inches in diameter and at least eight feet straight as an arrow with no limbs. I plan to air dry and use it for lumber and inlay/veneer material. Holly seems to develop blue streaks. Is there anything I can do to minimize this when I cut down the trees?
Re: Blue Holly
Re: Blue Holly
the blue is mold stain. Keep it from molding. Get surface dry as quick as possible. treating with fungicide may be beneficial and /or dipping in Chlorox at once and then more later.
Re: Blue Holly
Dale Lenz
Re: Blue Holly
Dale Lenz
If the holly tree isn't cut, wait until about the first of Nov. or later. The blue fungus growes above 50°F. If you can not, do as Bill says and get the shell of the wood dry as quick as you can. Eight to ten inch stems will likely cup during drying.
Good luck and enjoy
Re: Blue Holly
Air, air and more air.
basil
Stack with stickers and put a fan beside the stack immediately. Move the fan from side to side and end to end a few times a day if possible for a week or more then stop and allow to complete drying.
Re: Blue Holly
Alternative
Wash your boards with chlorine bleach and TSP, rinse, lay out in a single layer to surface dry before stacking and stickering and flip them every hour for the first 2 days. Stickering damp holly can get sticker-stain that will go straight through the board.
This from an old sawyer.
Re: Blue Holly
PS
For air drying when stacked, use 5/8" dowels when possible rather that flat/square strips. The round form minimizes contact with the boards, giving the same support but enhancing air-flow and reducing the opportunity for sticker stain to develop. You can shift the stack (rather than restacking) by simply pulling/pushing each board an inch or so. There are also plastic "stickers" available that have a pebbled surface to reduce contact with the boards.
Also, don't forget the weights. I use a line of 2" solid concrete block as the top layer on my stacks. At 25lbs each, I can put 200+ pounds on a stack line without too much effort and the boards come out nice and straight, even with air-dried cherry that loves to "dance" as it dries.
Re: Blue Holly
sticker stain
I have never seen or heard of a case of sticker stain with KD sticks. Some commercial sticks are fluted but this fluting it to facilitate the rapid drying cycles for species like poplar.
I think I recall a study out of VA Tech (Wengert) that sticker stain is a result of some chemical process and not mold.
Much lumber now days is dipped in something to prevent mold while drying and bugs after drying.
Re: Blue Holly
Re: sticker stain
Us air-drying boyos can get it all the time if we don't take care. I harvest, mill, and air-dry walnut, cherry, and maple. Used to do poplar (have tons of it on the property) but the stuff stained like crazy. I would use it only for secondary wood anyway, but it just wasn't worth the effort.
Don't have a kiln and don't do enough to warrant that kind of expense. I started using KD pine stickers, but since my drying goes for a year outside under tarp, then into the shop (restacked/restickered) I got better results with the method I was taught.
Re: Blue Holly
Dale Lenz
Re: Blue Holly
Dale Lenz
A sawmiller guy that I believe knows quite a bit told me once, on easy to stain wood to lean the boards up against something under a covered roof for a week or so. This will dry the lumber's shell and then stack to dry. Never tried that method, but should work. Just lean the boards up close to vertical to keep the boards from sagging.
Good luck and let us know how it turns out.
Re: Blue Holly
anything that quickly gets the surface dry works
Maple sawed in the summer months is particularly susceptible to staining. A large mill near where I grew up saws exclusively maple and cherry. For whatever reason they never installed a dip tank. As an alternative they put the maple on "shipping sticks" as soon as it is sawed. These sticks are about 1/4" thick and function to enable air to circulate between the layers of lumber, yet not take up much volume during shipping. Apparently this procedure is sufficient to prevent staining for the time it takes to ship the lumber to a drying/grading facility where it is put on thicker sticks for drying.
That said, I would still advise treating the holly surface with some fungicide, and, getting the surface dry as quick as possible. I have seen maple and pine with reduced circulation turn blue within two days in the summer.
Re: Blue Holly
Re: sticker stain
Sgian Dubh
"I think I recall a study out of VA Tech (Wengert) that sticker stain is a result of some chemical process and not mold.
You're correct Bill. You might still find a reference to it at the URL in this entry lifted from a bibliography I created in response to some research I undertook: Wengert EM, (2007) Sticker Stain, Chemical Stain, Iron Stain and Blue Stain, Woodweb, Montrose, PA, USA. [Online] Available at: <http://www.woodweb.com/knowledge_base/Causes_and_Cures_for_Stains_In_Dried_Lumber.html?printfriendly> [Accessed October 21, 2009]
To quote my text: "Sticker stain "is actually a result of the oxidation of naturally occurring chemicals within wood-- perhaps catalyzed by wood enzymes" (Wengert, 2007, p2). Sticker stain is the common term used, but the description sticker shadow is in fact the same as sticker stain. Quite frequently, conditions conducive to sticker stain or sticker shadow are also conducive to fungal growth; sticker stain is a likely result, particularly in white woods, where initial wood moisture content is above 40 percent, and there is less than 5 percent of moisture loss per day coupled with temperatures of 10º C (50ºF) or greater."" Slainte.
Re: Blue Holly
Re: Blue Holly
Sgian Dubh
What you're describing Dale is what's known over here in the UK as 'end racking' which is a technique to reduce the likelihood of mould developing and core discolouration in pale woods, particularly maples or European sycamore. Freshly milled boards or planks are reared on end with spacers between each board so that air can pass through quickly to rapidly remove surface moisture. After a period of end racking the boards can be stickered in piles and either air dried or kiln dried. Slainte.
Re: Blue Holly
Dale Lenz
Re: Blue Holly
Dale Lenz
Like your picture, Richard....But, if possible I'd still try to dry the wood outside, undercover. The wind blows free....so far....given time there will probably be a tax on wind!
Re: Blue Holly
Re: Blue Holly
Sgian Dubh
It's a little difficult to see in that image Dale, but if you look carefully you'll notice that you can see equipment or machinery beyond the line of the wall behind the end reared boards. I think this is a shed open at either end with curtain type side walls that stop some distance short of the ground. I'm not fully sure of that as the image isn't one I took, merely one I've been given permission to use, but if the shed is as open as I think it is, then it fulfils your criteria of protecting the wood from the elements yet allowing a through draft. Slainte.
Re: Blue Holly
Dale Lenz
Re: Blue Holly
Dale Lenz
Works for me. Around here a lot of one time wood dryers put the wood in the barn with the doors closed...Arrrrg.....:)
