Picture Frame wood
Picture Frame wood
Picture Frame wood
Dustmaker Mike
Howdy all I have not done much woodworking in the last few months. but it seems time for me to do a little bit. I went and got an estimate on framing a 16 by 20 inch picture. The frame my wife picked out I know I can make pretty easy. My problem is what type of wood should I use. It will be stained to a dark oak color with some painted highlights. My wife like a close grained wood I was thinking popular but not sure how well it would take a stain. What else should I look at? The molding will be 3 inch by maybe an 1 1/16 thick I will measure a few frames to see the thickness they range. Thanks Mike
Re: Picture Frame wood
Both basswood and poplar stain as good as it gets. We once sold lots of basswood to cabinet shops for face trim on birch cabinets to be stained.
for a painted frame I prefer maple. A glass smooth painted surface can be had by spraying it- kilz, sand, paint.
Clint Searl
Clear SPF 2x4
Kneale Brownson
Kneale Brownson
I've made frames from mahogany, maple, oak, pine and popple. I've finished them natural and stained them everything from lightly to dark. If you're planning "painted highlights", I'd use the maple Bill suggests and paint the dark color of the background before adding the highlights.
Lee Schierer in McKean, PA
Poplar accepts stains or paint. You can also use, black walnut, oak, cherry, hickory, mahogany, and most any other domestic or exotic wood.
Lee
Yonak
Mike, if you're going to stain it dark oak, oak would be perfect. In fact, just about all the woods mentioned would be good, plus ash, beech, pecan....
The only woods I would be cautious about, if you plan to stain, are cherry, birch, soft maple and walnut. Walnut because it's already pretty dark and walnut and cherry because staining only makes these beautiful woods less beautiful and cherry, maple and possibly birch because they tend to blotch if you don't pre-treat. I've never tried staining hard maple, but something tells me the crazy grain similarities with soft maple would give it the same blotching tendencies.
Also, poplar and basswood have been mentioned. They both take stain extremely well, but tend to look rather coarse after staining and may not be suitable for fine woodworking. Strictly my opinion.
Thanks All
Dustmaker Mike
I have a few pieces of poplar I will play with to see if it meets her taste. I would use Oak but she does not like the amount of grain. If that works then great if not I will be off wood shopping in the next few months. Thanks Again Mike
