Seeking help
Seeking help
Seeking help
Gary Smyth
I need a bit of help. Another flea market find. The table is veneered with an inlay on the center of the apron bow and the tapered spade foot legs have a stringing and a single bell flower which is what drew my attention to begin with. The table originated in Italy (maybe) (need translation) and I’m informed was part of the breakup of the home of a woman Captain in the U.S. Navy who had numerous overseas tours. This one is a bit of mystery. The hinged top of the bow front flips, and expands to a seven foot table with the three leaves that were included. Pictures will give a better look than my description. The problem/mystery is that when the table expands to its full length, the top, which flips on three hidden hinges, has no support. There are marks evident on the top which indicate that something supported that top when it was at full length and not gently. Should I consider making a support? Is this table missing something? I’m told the table is late 1940’s early 50’s. It has metal braces and latches and the screws are modern. I just don’t understand how it can be configured so that the top can drop into a flat surface with support if at its maximum length. I’m looking for opinions/thoughts/suggestions. [
Re: Seeking help
Bob
Re: Seeking help
Bob
I think it would be a good idea to translate what's on the tag and research what you can. It looks like an expensive piece because of the marqueterie.
Re: Seeking help
Hoping someone here could translate
Re: Seeking help
I could if
mike farinella
maybe the picture was a little bigger. Hard to see and most of the words are missing.
Re: Seeking help
Re: Seeking help
Joseph Mulherin, sr
Gary, if i might make an opinion...the sliding sections in the bottom left picture are the supportings for the leaves to rest on. When the table is extended they come out and you put the leaves on them and you then pull back the extended table end to lock the leaves together. I have a round table that use these extensions for when I raise the sides for the full roundness of the table....they work just fine.
Re: Seeking help
Re: Seeking help
I similarly could not resolve the components in the picture and remain confused by the parts .
However, I have a "round" table, 1910's, that has many extension slides. They are supported by a 5th leg in the middle. I could provide a picture if it would be helpful.
Re: Seeking help
Exceeded my duh quota
Gary Smyth
Thanks to all. I just went out to the garage where I stashed the table out of the rain to try to explain how the table top when flipped had no support. Today, without the threat of rain and the luxury of having the table reassembled I found my error.
1. Table from rear with top on
2. Table showing the direction of the "flip".
3. Demonstrating that when th mechanical lock is released (Surprise!) the table splits ALSO to the rear and pulls out. In my defense, when the table was unassembled, and me rushed with rain drops, I didn't contemplate that essential movement.
4. Rear of table pulled out to full extension providing full support to the flipped top.
5. Top on rear extension fully supported - flush with table leaves (when they are inserted)
6. All three leaves fit with front pulled to full length.
I'm a bit red faced. Thanks for the help. I should have caught it long before posting.
Now to judge if the table is worth refinishing (or having refinished) the scratched top.
Re: Seeking help
Here's a new look
Gary Smyth
This is 175% larger than the original label. Any words you recognize is a start. I'd love to have more but what is shown is all that exists. Con registore probably means with registration or something like it. This may have been a customs sticker to get it out of the country. Just guessing.
Re: Seeking help
hold down ctrl key and roll the wheel for bigger
del schisler
if you hold down the ctrl key and roll the roller on the mouse if you have one and the wording will get as big as you want good luck if not i can make it bigger and post back ?
Re: Seeking help
Re: Here's a new look
Merle
Use Google Translate
http://translate.google.com/
Maybe you will be able to piece enough of it together to make some sense.
Re: Seeking help
Del
Gary Smyth
Working in Picasa 3 using your control wheel roll method, or progressive hits of the + icon I can expand the picture to practically fill the screen. I save it and transfer that image back as a new photo (I thought). When I call it up it reverts to the original size. It even asks if I want to replace the old image with the new. I check yes.
If I attempt to post the enlarged image directly it still goes back to the original size that was posted yesterday. If I take the posted image and edit in Picasa, it will go there and there I can enlarge it for my personal viewing, but I haven't been able to get the enlarged image to transfer when I post. If you wish to take time to do it for me please feel free. Thanks
Re: Seeking help
Translation appears not related
Gary Smyth
con registratore -- with recorder
dotata de equilizzatore -- with equalizer
un ascolto forte -- a strong listen
vendita di miglore -- sale of better/best
Maybe radio or audio stuff.
Re: Seeking help
Re: Exceeded my duh quota
Joseph Mulherin, sr
Glad we all could have helped you find the solution.
Re: Seeking help
Bob
Bob
Not sure where your located but Patrick Edwards and Patrice Lejeune
could nail it down to almost the day it was made but you may not want to pay for the service. I would Google every name I could think of until I came up with a photo there are most likely more then one out there.
Re: Seeking help
Jack Guzman from Maine
OT. WOW!
I didn't know my computer did that. Neat trick. Learn something new every day.---Jack
