OT: Video Formats
OT: Video Formats
OT: Video Formats
Stuart Johnson
My wife has signed up for a series of sewing videos. She is running on Vista and is unable to view them once downloaded. I have two questions.
1. Her download speed using speedtest.net is around 5.12 mbps. Downloads from the sewing site run between 50-70 kbps or a couple hours for a 270mb file. Is this an issue with the sending site or something that can be done on my end?
2. The video files are .M4V which I think are some sort of protected Apple format. Is this correct and how can they be converted to something useable on Vista?
Thanks,
Stuart
Re: OT: Video Formats
John McGaw
Yes, M4V is Apple's very own botched take on the standard MP4. It supports their money-grubbing iTunes. The files you have may or may not be "protected" from viewing. If it were me, I'd download and install the free VLC media player and give it a try as it is about the most universal way to play video. If it won't handle it then you may be forced to deal with iTunes. I have no idea how to do that, having avoided that particular demon.
Bill Howatt
If your test runs at around 5Mbps then the problem is at the sending end or the routing to your home. Most likely the sending end if it consistently is slow.
M4V which is an Apple bastardization of MP4 and may contain Digital Rights Management stuff. You are just going to have to try to open run it if you haven't. Supposedly the Windows Media Player is supposed to handle them but that likely means one with no DRM. Apple QuickTime should play them too.
Bill
RobCarr
Try this...
K-Lite Codec Pack is a collection of codecs and related tools. Codecs are required to encode and/or decode (play) audio and video. The K-Lite Codec Pack is designed as a user-friendly solution for playing all your movie files. With the K-Lite Codec Pack you should be able to play 99% of all the movies that you download from the internet.
http://www.freecodec.com/download/K_Lite_Codec_Pack.htm
Re: OT: Video Formats ..Thanks
Stuart Johnson
VLC media player did the trick.
