Have a question? Ask Woody!
Need drawer slide help
mildbill
I'm building some shop cabinets and need some advice on the drawer slides. I made the cabinets from 3/4 in. plywood and poplar for the face frames. I've never done drawers so I'm not sure how to choose the slides or which type would be the easiest to install. Do they sell installation jigs to make putting them in simpler. The depth from the inside of the face frame to the back of the cabinet is 21 inches. The FF is 3/4 in. thick. I'm not sure if more information is needed so let me know. Also what is a decent brand or particular slide to use, just want something that will hold up to a shop environment. The drawer itself will be in the neighborhood of 6"hx14"wx18"d or 20".
Thanks, Bill
Re: Need drawer slide help
Accuride or equivalent . They work so smoothly that I used them everywhere.
John in NM
If everything is nice and square, drawer glides are easy to install. For full extension I like the Accuride type, for cheaper installations where 3/4 extension is acceptable, standard Blum's work very well. I've never tried a jig of any kind for either.
I've no experience with any other type - all those "invisible" slides strike me as rather silly, but that's just me.
Basically, all you do is take the glide apart, install the bit that goes on the drawer box (Accuride types can go anywhere you like, the standard Blum wraps the bottom corner of the drawer box). Then you figure out where the other half needs to go in the cabinet box to get the drawer box where you want it. Install that half using the oval holes and check the fit.
If you're lucky (or perhaps really good :D ) little or no tweaking will be required. If you need to adjust things, that's why you used the oval holes. It takes a good 3-d imagination to figure out which part needs to move which way, but you quickly get the hang of that. With nice square parts, you won't need to shim behind any of the glide parts, just adjust in and out, up and down.
Jim Dillon
Bill,
I also have had good luck with Accuride slides, as well as those sold by Lee Valley. The sliders I have used required a 1/2-inch clearance on each side. The length should not exceed the inside dimension of your cabinet (minus face frame). In your case a 20-inch slider, if available, would work fine. It's a personal choice regarding full-extension or 3/4 extension, but the full-extension would be nice, especially for the relatively small drawer your are building. Accuride used to make a slider that had built-in lips on the bottom to facilitate placement of the drawer. That was a very useful feature, but I don't know if they are still made. For multiple drawers in a cabinet, I have used pieces of scrap wood cut to the same length, starting with the top-most drawer, to make placement of the slide easier. Then simply cut the pieces to a shorter length for the lower drawers. At most, a 100# capacity would be OK, but that is a lot of weight for a drawer that small. A 75# capacity would likely work well. They also make super heavy-duty sliders, but they are intended for filing cabinets filled with heavy files that are often fully extended.
I've ordered most of my slides from CabinetParts.com.
Jim
I agree with all of the above. I would add a couple of thoughts. I used full extension rails on the drawers in my lathe cabinet. May have been a mistake. The parts are greased. They basically run in grease. I find that enough crud seeps in to make them feel gritty. Periodically I have to blow the crud out of them. (Note to self: wipe as much grease out of them as possible.) Because they are sort of interlocking, they tend to latch onto the crud. OTOH, the 3/4 extension runners tend to let the stuff sift out of them.
I find that I can buy knock off runners at a local professional cabinet supply house for about a third of what the Borgs sell them for. $4 beats the heck out of $13. Be sure to ask them for the screws.
And, I find its a good idea to buy Heavier duty ones rather than light weight. They are sturdier and run better, much smoother.
don stephan
I've always used K&V slides, usually full extension, because that is what was recommended by a cabinetmaker in about 1980. Some of my workshop cabinets were built in the early 1980's and I've never had to replace a slide or had any failure. Not sure but I think they are number 8300.
I'd suggest building a sample drawer opening and install the slides for practice, before moving on to your cabinets. If your face frame extends into the cabinet opening you'll have to shim flush with the face frame behind the slides.
Second Accuride. Seen none better...
