OT computer died
OT computer died
OT computer died
James Runchey
I was on my Toshiba laptop, the power cord plugged in when everything went black, not a single lite lit
Is it toast? Nothing would bring it back to life.
Re: OT computer died
Jiggle the cord.
Stuart Johnson
If your battery is shot you might try a different cord/ powerpack. If the battery is good then you probably have another problem. How old is the machine? Anymore it is almost cheaper to buy new than to replace.
time for a pro
J Baird sw chicago burbs
I had the exact same problem with my Toshiba lap top . I took the battery out, two minutes later put battery back plugged in cord. Turned on lap top and everything is good. John b
Brian from Monument
As others have said remove battery let sit.
Reinstall battery and try again.
If it is really dead.
Time for a new machine.
Take your old machine to Best Buy or (similar geek squad unit) and have them place the drive in a external drive pack so you can copy valuable items from your old drive.
Works good. Old stuff will fade from memory fast.
Back some 17 or so years ago, when I was working as a software developer at MCI all the managers had gotten new Toshiba laptops/notebook computers (while us working grunts got nothing). Several weeks into months went by and then many of the managers computers started failing from bad hard drives.
Good luck with your computer, Hope its only a tempermental battery.
Could be a reminder to do backups, if you don't already do them.
John McGaw
Most laptops have an LED adjacent to the receptacle where the power brick connects. This LED illuminates when the computer is receiving power from the brick and it is not controlled by anything else in the machine. If your machine is connected to the AC mains and the light is not on then it is highly likely that a) the brick is defective or b) the connection is broken. The first is easy to test if you have a voltmeter -- it should be putting out whatever DC voltage is called out on its label. The second is not so easy since it entails digging into the computer's guts and with a laptop this is never pleasant. Sadly the broken connection scenario is pretty common as people do things like stressing the fragile connection by tripping on the cord.
Rick Christopherson
Taking the battery out is good advise, but it is not to let it sit. What this is doing is cleaning the battery contacts by removing it and reinserting it. So instead of letting it sit, you just repeat taking it out several times.
However, that may not fully correct your problem because it is likely that you have 2 separate problems. The battery connection problem could have been hidden from you for some time now, as long as you typically keep the power supply plugged in.
Unless the power supply physically plugs into the battery (not likely), It would still power the laptop regardless of the condition of the battery or its contacts. The only way for the laptop to instantly shut down without a battery warning is that both battery and power supply stopped giving power to the laptop.
You'll need to troubleshoot the power supply too. I'm not sure, but it's possible the Geek Squad could even test the power supply for you.
By the way, after messing with the battery, you may discover that it still had some charge on it before it lost connection. So the laptop may restart, but you will still need to plug the power supply in for it to stay running.
Robin Corell in Atascadero,CA
I have a Toshiba net book and the same thing happened to me about a month ago. My problem turned out to be a dead battery charger. It was easy to diagnose with a multi meter. And worth a new charger it's up a running just fine.
Robin
James Runchey
Hey Robin
When your laptop died were there any lites lit at all?
