Dealing with glue where it shouldn't be
I am surprised that woodworkers that have demonstrated considerable skill in building fine furniture are dealing with glue squeezing out where it shouldn't (by oiling and the like)rather than avoiding the problem to begin with. This isn't a problem an experienced woodworker should have. Inexperienced woodworkers should be learning how to avoid it as they develop their other skills.
I took a class in the Mack Headley and Sons shop (a woodworking life altering experience, should you ever get the opportunity to take a class there). Steve and Jeff emphasized proper fitting joints and proper glue application on these joints. If glue is squeezing out where it shouldn't too much was applied, end of story. From their lectures I got the impression that their students typically used too much glue it was their mission in life to fix this problem.
It takes but two molecular layers of glue molecules to create the bond, one stuck to one side of the joint and vice versa. Any additional glue either fills the gaps or gets (or should get) squeezed out.
Unless it is a joint where excessive squeeze out doesn't matter I rarely apply glue from the glue bottle. I have a collection of small cups I get at the restaurant supply store (used for salad dressing etc) which I add glue to. It gets transferred from here to the joint with an acid brush (the metal handled affairs with the short stiff bristles which I buy by the 100) or a thin small lab spatula. The spatula is ideal for M&T joints where glue can be slathered in the mortise but only a very thin layer goes on the tenon. The spatula both applies and scrapes off the excess. Larger glue surfaces are coated using the acid brush. Very large surfaces are coated with a paint brush. But in all cases glue is applied as though it was paint and I wanted to avoid runs.
Years of practice avoiding squeeze-out becomes essential when dealing with an application like this cock beading. Here is a place the acid brush was used, painting on a thin coat of glue on both surfaces up near but not up to the show edge.
Bottom line-strive to avoid squeeze out rather than deal with it later.
This seems to sound too preachy but I'm too tired to try to fix it. The objective is to provide encouragement, not criticism.
