Re: Uhg. Set back on my desk project.
Joe in a Cleveland suburb
Hello all.
I just wanted to respond to some of the comments regarding my little mishap and let you all know I appreciate you taking the time to respond and try to help. Thank you.
Stephen Kirk said:
I've been there. Repair if you can, fill the opening with a different wood and call it an accent. Otherwise, remake the part. It really is frustrating when a bit raises like that!
I am making a new drawer front (and sides). The grain won't be an exact match, but I am going to try and do cock beading around it so it looks like it was supposed to be that way...
Mark Mandell said:
BTW, a good stacked dado set makes things very easy and precise as long as the you don't need the dado to be of the "stopped" variety."
Stupid me. I should have used my (Frued SD208) stacked dado set. Sometimes I make the mistake of rushing and not thinking thrings through.
Lee Schierer said:
The test run on scrap usually insures that the finish piece come out right the first time.
I understand. I had actually routed the grooves in the drawer sides first to make sure all was ok. Guess the router just didn't like the drawer front.
Henry (Raleigh NC) said:
After the third or so occasion of this type of routing "event" I decided that a 'real' router was in order.
I agree. When I buy a tool, I try to buy quality when I can (afford it). My routers are a couple PC7529's and a couple Hitachi M12V's. I have a cheapo router I bought at Sears close to 20 years ago. Haven't used it in close to 20 years...
Joe Burke said:
I don't hesitate to make cuts in steps as opposed to hogging all the material out at once.
I should have thought of that.
I'm not trying to lecture here at all.
Not taken as a lecture and I appreciate the time taken for the reply.
del schisler said:
or the bit was bottom out,
Not sure that was the problem, I don't know, but when I put a bit into the collet, I bottom it out then raise it back up an 1/8" or so.
Thomas Skaggs said:
Routers can sure make scrap wood in a hurry!
Ain't that the truth!
William Duffield said:
It's difficult for us to help you analyze your problem if we don't know what kind of router or what kind of router lift you are using.
I was using one of my Hitachi M12v's that is dedicated to my (crappy) router table that is attached to my cabinet saw. It was a 1/4" bit in one of those adapter for using a 1/4" bit in a 1/2" collet. I have to take the time to have a good look at that adapter/collet to inspect for what you and others have said. The rest of your post made total sense as well.
Keith Newton said:
When you put the bit in, lift it off the bottom a little before tightening.
I did. See above. Like I mention, I need to take a closer look at the collet.
Thanks a ton everybody.
