How do you calculate the size of a load bearing beam. I am wanting to remove a load bearing wall and make 2 bed rooms into a larger master bedroom. part of the equation is there is a upstairs above the 2 rooms 2 more bed rooms. Would 2-2X12X12' long boards be sufficient? how about 3-2X10X12 boards? to preserve some head room effect.
but I suggest paying for an engineer. You'll need span and load numbers. Load numbers are both in live and dead load. Don't know where you are located, but snow loads figure into the calculations if you are in the snow belt. I suspect you will need steel in there, but some of the engineered timber has pretty good numbers.
Been awhile. Nice to see you post. When I do that I ask the guy that runs my lumberyard. He keeps a chart under the counter.You can get better strength with less depth using what they call an LVL beam. It's a laminated beam.
My ten foot bedroom needed a 6x10 beam with no floor above. It had to support the roof. You may need to use steel. An Ibeam will hold alot of weight with less depth.Or you could Google "beam calculator". Good luck.---Jack
The short answer is to pay an engineer to do the calculation. What will safely hold something up is much less than what will prevent the floor above from being springy.
From my experience working on houses in TN...
I have not seen a 12' span supported by 2 or even 3- 2 x 12's. I think this would be too springy. Two 2 x's with a 3/4" piece of plywood glued between increases the stiffness a lot. It is commonly used in these parts for moderate spans. I have several in the house I am in. For longer spans 2-2x's with a 1/2" steel plate bolted between makes a stiff beam and it would be a common way here to span 12'. This arrangement is superior to an I-beam from the builders perspective because it is easy to install and I have heard it argued that it is stiffer. The 1/2" web is thicker than a light I-beam to provide stiffness and the wood on either side resists deflection which is important to load bearing.
You can get some info at a good lumber yard, because the can hook you up with their LVL engineer. You will need to give them lots more details than you know to ask about, judging from your vague question.
Nobody here has a clue which way the floor joist, nor the ceiling above runs, what your roof is, and whether any of that is on this wall.
And even knowing all of the above, don't forget to look down. You can get it all perfectly sized above, but not be over foundation support below, and have too much of a load point under the ends of this new header. This is especially critical if the floor joist are some of the new engineered type. They can carry a huge load, all spread out, but buckle under the same load concentrated in a small area.
Not to put a fly in the ointment, but I would expect that you should be pulling a permit to do the work that you describe. The housing department would require some sort of structural analysis. That means a structural engineer or an architect. In any event unless you know what you are doing, you really do have a fool for a client.
The guy at the lumber yard is only trying to sell you wood.
Particularly something he can make a handsome profit.
