Re: thanks all- still a question
Grant in Iowa
Using "cap" on ribs, I usually find it takes about 5 hours for best results. My Weber bullet is black in color so as the sun goes over the house I have to adjust air vents to keep temps in the butter zone of 200-240 F.
Make sure you have trimmed off as much fat from them as possible before cooking. It sounds counter intuitive, but the fat doesn't really add much to the finished product in the case of ribs at smoking temps. I also remove the silver membrane from the underside of the ribs to enable me to effectively treat that area with rub as well.
Ribs in the smoker don't tend to fall off the bone. This is because the smoking process tends to convert at least part of the meat in to a ham like product before the cooking can cause it to fall off the bone. Note that I am speaking of true smoking, not about "cooking on a smoker" here.
I know I am too late with my recipe below, but put it in your recipe box for next time.
By the way, the best way I have found to reheat ribs the next day is to put them in a steamer of some kind.
FWIW,
Grant in Iowa
