Cock bead Joinery
Cock bead Joinery
Cock bead Joinery
Step one is to make the cock beading . I rip strips on the table saw or band saw and sand to thickness on a drum sander. The edge is rounded with a scraper. I like to use a scraper because it leaves some irregularities which given the beading a handmade look and feel.
PIC 1
PIC 2
The top and bottom bead will be put on and off the drawer twice so some means of exactly repositioning it are necessary. I accomplish this by driving three brads into the drawer edge and cutting the head off to make a sharp point. If not dealing with black glass (AKA African Blackwood) these brads punch alignment holes into the to- be- fitted cock bead strip.
PIC 3
The next step is to press the strip into position on the alignment pins and clamp it securely. Plane the ends flush with the side of the drawer. Now the length is established. While in position mark the transition point between the more narrow side cock bead rabbit to establish the stopping point of the stopped meter.
PIC 4
Remove the bead strip and fasten it to a guide black to pare the stopped miter.
PIC 5
Picture 5 shows the stopped mitered bead strip ready to be glued to the drawer(the bead is flipped upside down to show the shape. The alignment pins ( a pin and the hole it made are seen in the picture) will ensure it is repositioned precisely on the drawer.
Picture 6 shows a completed drawer. This drawer is for a Federal “Lite” Bow Front chest of drawers I made last year.
Re: Cock bead Joinery
Jack Plane
A nice clear tutorial.
I normally plane the profile on cock beads as I find a scratchstock creates too many undulations in such narrow stock.
I glue and nail the major lengths of bead in place and then mitre their ends in situ and then mitre the shorts by eye against a bench dog using a chisel.
questions
"I normally plane the profile on cock beads as I find a scratchstock creates too many undulations in such narrow stock." Not sure what you mean here. If I use some care the beads a smooth across the top. The "scratcher" bottoms out when the bead is formed and quits cutting.
" mitre their ends in situ ." This would be quicker but I don't see a way to do it. How?
Re: questions
Jack Plane
Once the beads are glued in place, I take a chisel and make a couple of paring cuts to form the mitres.
Re: questions
In other words "free-hand" the miter cut with bottom tip of chisel?
That is a bold cut to do on a glued in place bead strip. You have more confidence and experience than I, but I can see than in an easily pared wood like mahogany it could go well.
planing the profile on the cock bead,and thankyou
I must admit that I was skeptical of my ability to plane the profile and have the result look more or less rounded. Well, I messed up the miter on the last short piece and needed to quickly make another. What I had left for stock was too short to clamp and scrape. Inspired, holding a block plane in one hand and the short piece of stock in the other I started to plane facets on the edge and then rounded them over. Literally in seconds I had a quite presentable profile on the edge with no lumps and digs from the scraper.
Yet another tidbit from your wealth of information to file away to be used to advantage later. Thank you.
Clint Searl
Clint Searl
Aside from any aesthetic consideration, did cock beading originate as a functional element? The fussiness of the process begs the question.
Sgian Dubh
It protects the edge of the veneer applied to the drawer front. Cockbeading is generally easier to replace than trimming in pieces of replacement veneer which has become damaged through, for example, careless fingers, or abrasion against either a vertical or horizontal divider. In a sense, cockbeading replicates the functionality of the equally 'fussy' yet decorative cross banding and stringing arrangements around the perimeter of tables, cabinet tops and the like, most commonly seen in old or antique furniture, and less commonly applied to contemporary designs. Slainte.
Clint Searl
Thanks
Clint Searl
So, for a solid drawer face, it's only decorative.
William Duffield
We've been discussing this, but maybe it was in the other thread. Yes, there are three functional reasons for adding it, or maybe two and a half, depending on how you count, or your definition of "functional" in this context. First is the protection of the edge from bumps and gnashes. Second is to make any inconsistencies in drawer fitting (uneven gaps all around) less obvious. Third is to cover the end grain of the drawer front, which slows moisture transfer, thus minimizing warpage of the drawer front.
As an aside, note that on cheaper or more "vernacular" furniture, instead of an applied cock bead, the drawers often had a scratch bead. This was usually applied with a scratch stock, and often resulted in chipout on the end grain, or especially on the corners where two scratches crossed.
On other styles of furniture, a scratch bead was applied to the carcass sides and drawer blades, instead of to the drawer itself. This was much nicer, IMHO, because all the beads were long grain. The trick was cutting the sliding dovetails joining the blade to the carcass. I can't find an illustration right now, so I'll have to get back to you on this one.
Welcome, Jack *LINK*
We're delighted to have you join the conversation here. Your expertise and comments are most welcome anytime. I've posted a link below to your Pegs and 'Tails blog for any of our other visitors who may not be familiar with your work.
Thanks again for joining us.
Ellis Walentine, Host
WoodCentral
Jack Plane's "Pegs and 'Tails" Blog
Re: questions
Jack Plane
It goes well in mahogany, walnut, ash, oak, elm and rosewood etc. ;)
Re: Welcome, Jack
Jack Plane
Thank you. Very generous words and gesture!
Re: Cock bead Joinery *LINK*
Jack Plane
Is this the sort of thing you mean?
D-moulding
Clint Searl
Clint Searl
I think Richard's explanation is the most credible. The rest is hogwash.
William Duffield
No, that's not it.
This was a feature found on pre-revolutionary pieces developed in Boston, Newport and Connecticut. On this side of the Pond, we call the style Queen Anne.
I've found some detailed photographs. The best ones I've found are on Tony Kubalak's website. For example,
http://tonykubalak.com/Gallery/F_G_Case_Pieces/B_P_Bombe/Large/IMG_7917.JPG
In these pieces, the bead is not applied to the cabinet, but carved into the case sides and drawer blades. I haven't done one of these myself, so I can't explain the joinery in three dimensions, but the dovetail does not extend very deeply into the case components. Behind it is a stopped stub tenon.
I'll try to get a copy of a more detailed drawing tomorrow. In the meantime, the technique is illustrated in the Taunton Press compendium, Fine WoodWorking on Making Period Furniture, on pp. 69 and 75, if you have a copy. This book consists of articles from FWW issues prior to 1985.
Jack Plane
Sorry, my mistake. I've seen exactly what you describe, though it is rare in British furniture.
This is an equally unusual variation...
Carcase cockbeading with mason's mitres.
About your example
Jack, here is a photo lifted from the page you referenced...
and here is a marked-up copy showing my understanding of the mason's miter, with the rail outlined in a white dashed line. Am I mistaken?
Re: About your example *LINK*
Jack Plane
You're correct too, of course. Maybe the one I illustrated is an 'in-the-carcase cock-beader's mitre'. :\
If you look at the stone window in the picture above the mitred carcase bead on my blog, the mason's mitre at the top of the window is identical to the one on the dresser base (albeit rotated 90°).
http://pegsandtails.files.wordpress.com/2009/10/masons_mitre_01.jpg?w=640
William Duffield
Yes, Ellis, you are a bit confused. The construction of the dresser base whose picture you annotated does not match the lines you added. It uses, as Jack describes, a mason's miter, in which none of the joinery is cut at 45°, and all the decorative elements are carved onto the joined surfaces. In this photo the "miter" is suggested by a small scoop in the corner done with a gouge. The bead's return was also carved into the stile, exposing a wee bit of end grain. Also, note that the M&T joint moved some time after the original joinery and decoration were completed. The drawer blade or case bottom has shifted downward about a 32nd with respect to the case side.
Your drawing actually applies to the first case Jack illustrates, the 1770 dresser base. (The pictures are of two different cases!) This cock bead was not done with a "mason's miter." As in raised panel doors, like ones I've built and Bill has built, the cock bead was run all the way to the end of the rails and the stiles with either a scratch stop or a moulding plane, before the joinery was complete. The decorated portion of the end of the stile was then cut away, and both components were mitered to the width of the bead and to the total depth of the rail and stile.
Note also that none of the stones in the window are joined with miters. All the joints are either horizontal or vertical. All the miters are carved into the surfaces.
Joe in a Cleveland suburb
Awesome work Bill.
I have two questions:
1. Why is the cock beading wider on the top of the drawer and bottom of the drawer?
2. What method/technique did you use to cut the rabbets in the drawer top, sides, and bottom?
Thanks!
1. Why is the cock beading wider on the top of the drawer and bottom of the drawer? It isn't The bread board is 0.110" thick everywhere.
2. What method/technique did you use to cut the rabbets in the drawer top, sides, and bottom? table saw, rip blade, slow feed to prevent chip out.
