Wood threaded nuts *LINK*
Laurie
Hi.. I am needing 4 threaded wooden nuts... anyone out there have some laying around, or the tap and die to make some? They are like the ones on this link for a Walter Kircher spinning wheel.. they are either 3/4" or 7/8" (not sure how to measure.. the "core" or the threads). I am not about to spend the $50ish on a tap and die set for 4 nuts. I guess I could permanently glue the thing together.. but that would be sad.... Thanks... :\
Walter Kircher Spinnrad (nuts)
Re: Wood threaded nuts *LINK*
Janice Manuel
I can make wood threads in several sizes and the nuts too...I use a Beall Threader...
E-mail me....
Stuart Johnson
If you don't find what you need and the nuts are for the legs you could drill a hole, epoxy in a bold and use a large washer and nut.
William Duffield
The diameter you need to specify is the outside diameter of the bolt, which is the 7/8" of your nuts. There is another critical parameter, the number of threads per inch.
If you ask on the Hand Tool forum, there is a much better chance you will find someone who can help you. At least one of the guys over there has restored antique spinning wheels. The Beall threader works fine, too. It has two components. The router jig works on bolts with external threads, but you need to have the tap to thread the nuts. IIRC, the Beall cuts Imperial threads. Since this machine is made in Germany, you might need a tap in a metric thread size. Is yours model SRII? That's the only one I see that has obvious nuts.
You might also try to contact the company that makes them to see if they have spare parts, at info@ketteundschuss.de Even though their website is in German only, there's a very good chance that they can also read English.
Another group of people where you should be able to find some help is the Society of American Period Furniture Makers. Go to SAPFM.org, and near the upper left corner is a place to click Member Forum. Go down to "The Business of Furniture Making" and select "Wanted: Looking for…". Near the upper right corner, select "New Topic" and post your request and contact information.
With a hacksaw and a file and a bolt the right size you can make your own tap, which will work well enough to make four nuts, if you select the right wood and choose the right thread orientation.
Laurie
Wow! You all are great! Nicest people ever! I am going to measure more accurately, count threads per inch, and go through all the possibilities later this week.... From contacting Janice, Stuart's very clever (if all else fails) great idea, and a deeper understanding of my need and problem from William. Thank you so much! It's been a long time since I bumped into such helpful people!
Kind words
Glad you found us, Laurie. Let us know how your project turns out.
WoodCentral Host
Laurie
So.. I contacted the company in Germany (thanks for that suggestion). I was grateful someone spoke English, as I speak no German. It was still cute to have the response: "I do not know the English name "nut". Can you send me a photo from the "nut"? Anyway, with shipping from Germany, for 4 nuts, it comes to $32.02. I haven't ruled it out, but that seems like a lot of money (especially because I don't know if this is a decent working spinning wheel), and I might check the other options everyone gave me.
Onward and upward... or.. as the wheel turns.... something like that....
-Laurie
