I have a squirrel cage furnace motor that is about 30 years old. The motor was working fine when removed from the furnace. I had to get a new capacitor because I knocked the old one off. Anyway, I am using the fan in my spray booth. The motor runs fine for a while and then stops. Later it will start again. Any suggestions are welcome. Jerry
Sounds like a heat related wiring problem. If there is an insulation failure, heated and expanded wireing can cause an insulation crack to open and create a short.
Try closing off part of the discharge to create some back pressure. You are probably overloading the fan motor. On a continuous situation air is very heavy. We are talking Pounds not ounces. If I remember my science correctly a cubic yard of air weighs a pound. The duct system on a furnace provides the back pressure.
This is most likely your problem; I had the same using an old furnace blower. If you want to maximize the flow for the motor's capacity, put a clamp-on ammeter on a wire to the motor and then adjust the "obstacle" so the motor current falls to the rated value on the motor's spec plate.
i didn't read any post before i posted but i guess it was answard all ready thanks for reading
sound's like the thurmel heet protection unit on the motor is cutting off, did you close off some of the full opening a little or like close some of the opening , try this and the fan should run faster could be most try and take in the same amount of air and that make the motor work harder, now if you close some opening down that will take the load off the motor,,, i guess it is like trying to pull the same amount in and the same amount out which make to much preasure . my 2 cents
Do not close the intake you will burn it up. Closing the discharge is the proper way to un-load it. I know this is counter-intuitive. Fluid mechanics do not necessarily meet with COMMON sense.
Stuck a gallon can in front of the outfeed and the speed of the fan increased and did not shut off from overheating. I probably could have used smaller blocking. Now to keep sweat from dripping in the finish. Jerry
