Stored Lumber and Acquired Bugs
Joe Burke
It acquired something anyway. I've searched the archives and Googled, but I'd still like more direct input.
I had to store some lumber in an old barn about 8 years ago. I didn't have many options. Anyway, I've been in and out over the years, but I had to relocate my stash this week ... again, no options ... and I got a good look at the stuff. I have a definite insect/worm issue of some sort. The issue seems to be limited to some hard maple, as far as I can tell at this point anyway.
Small holes ... say 1mm dia ... surrounded by frass (very fine powder dust).
So far research has turned up powder post beetles. Sound likely?
The lumber was all kiln dried, but of course, over 8 years I'm sure the MC hovered around 12-14%.
I suppose my questions are typical. Bugs still in .. or out? Left eggs behind? Will they attack any species? All the usual suspects were there ... cherry, walnut, mahogany ... but I still say I've seen the evidence on maple only. Use the wood or not? I've read that heat would kill them off. How about freezer time?
I know that without seeing the evidence it's a tough call, but cut to the chase for me. What am I most likely dealing with? What are the hard facts?
Re: Stored Lumber and Acquired Bugs
Your research seems correct. Put it back in the kiln and make a solar "cooker" with black plastic. Get it back to 180 and they're done.
you have powder post beetles damage. It will be much worse than it appears. The maple may be useless.They usually attack sap wood only.
Odds are they have come and gone. That is the usual situation.
Most sure way to kill them if they are still around is to heat the lumber. Never tried it, but fumigation under a "tent" should work. Whole houses are effectively fumigated so it will work for a lumber pile on sticks if done "right", however that might be.
Stored lumber should always be treated. I spray a persistent insecticide, Lindane and it has never failed to provide protection.
Gene Gauss
I recently bought about 150 board feet of black birch and white oak, rough sawed to my order from logs that had been cut about a year ago. I've stored it in my old barn, carefully stickered and off the wooden barn floor. I'm in upstate NY, where the outdoor temperatures can be expected to range between -20F and +90F with humidity between about 40% and 80%, with an occasional brief 100%. Reading this thread, I became concerned that I should be using some insecticide to prevent infestation while I let it air dry. I plan to use it in about a year. This is my first try at this and insecticide didn't occur to me. Is there something I should consider in terms of assuring infestation doesn't occur?
Mark, 180 seems high, try 160
Keith Newton
I've gotten it there with a little electric heater blowing through a little window cut into a tarp draped over a 1" foam board roof suspended over my stack.
I used foam under the stack as well. Anything that puts the BTUs into the wood, rather than lost helps.
my experience
I don't know about NY but here in TN you could expect the sap of the white oak to be attacked eventually. It might be a year or 10. I store lots of lumber, about 7,000 bdft currently. I have been storing lumber for many years. Before I became aware of the bug problem (commercial lumber is often treated at the mill to prevent this problem) I got attacked and a substantial quantity of ash, white oak and walnut was damaged/ruined. Attack in the ash was total destruction. So, I started spraying the rough lumber with Lindane to wet all surfaces. I have lumber so stored 20 years outside and inside and have never had a reoccurrence of insect damage.
I used Lindane because it is persistent, and at the time cheap and given that for generations it was used to treat head lice and dog fleas as a shampoo I was not paranoid fearful of using it. DDT would be another good choice, if you have some left over from the 1960's. Something related to pentachlorophenol was historically used at mills, and "penta" would be excellent, but don't breath the planer shaving dust. I don't know what to recommend now days. Probably anything that will kill ants may work, or ground treatment for termites. Or, if there is an orchard near by get what they used for trunk borers in peach and cherry. There is a "green" friendly borate compound, but I have no experience with it.
Kneale Brownson
Re: my experience *LINK*
Kneale Brownson
Lindane doesn't get very good marks from the environmental/health standpoint: "Lindane is an antiquated and toxic pesticide"
Click Here
Bill, Haven't you previously recommended Boracare?
Chad Pearson
I seem to recall you talking about Boracare in the past and based on that recommendation used it for lumber stored in a shed as a preventative measure.
In any event, Boracare has worked for me as I have seen no evidence of bug infestation with the treated boards.
some insecticide for the bugs, some for you
Dick Coers
If you use it on the wood, and then mill and sand the wood, I suspect you are going to get a dose of insecticide as well. Heat is the only way I've read to kill any eggs left in the wood. I think you need the core of the wood to get to around 140 degrees for 24 hours to be certain the eggs and bugs are dead. What you will find inside the wood, behind those tiny holes, are tunnels. Maybe you have enough thickness to get under the tunnels, but I'm sure some of it will be lost.
they have to have oxygen
If you can diffuse something that will kill them along with air they need to live to where ever they are located they will die. Hence, any volatile bug killer added to a "tented" pile of wood should , it would seem, kill them. However, if heating is a practical option that is the thing to do.
not me
I have no experience with this material. I still have a 1/2 gallon of Lindane so the dire warnings not withstanding I will continue to use it as needed.
Up until about 1980 the sodium salt of tetrachlorophenol (close cousin of "penta") was used to treat most hardwood lumber by dipping. That is stuff even I consider bad news. Now days something else is used as seen in the pack being dipped in the picture. What ever it is it kills bugs and mold.
