OT, Odor removal from house?
I have a house where Cat Lady lived for a long time. She passed away. I think she smoked. The house is painted with what appears to be gloss or at least semi gloss paint. Has vinyl block tile flooring. the house stinks, but not as badly as I thought it would. I was scrubbing the Cat Room today. Lots of scrubbing.
Any advice on what to scrub with? I am thinking of carpeting most of the house. After I scrub the floor.
Re: OT, Odor removal from house?
Probably need more than scrubbing
Dick Coers
Depends on the subfloor, but probably cat urine in the floor (not on it). I'd probably start with TSP, and when dry, coat everything (including subfloor) with Kilz primer and repaint walls and ceiling. Ozone generator will also kill the smell, but not if it's soaked into the wood subfloor. 55 gallon drum of Fabreze?
Kneale Brownson
Kneale Brownson
Shellac the floor before you carpet over it. Couple coats will "hide" the cat pee that undoubtedly saturated the subflooring under the tiles.
Steve Mackay
I've used those odor killers that are available at pet stores. They do OK. I suppose you could put it in some sort of sprayer rig ?
"Febreze" works even better. But might get a little spendy for your, rather large, application.
I wish you luck brother. Not a job I envy you !
John McGaw
My good friends buy and sell foreclosures. They are also owners of scores of rental units. They bought the place right next to mine, partly as an act of mercy toward me, which was occupied by some of the nastiest dirtiest people I've ever seen. They eventually had to bring in a remediation company to do an extensive ozone treatment on the place even after their staff repair crew had stripped the place of the worst flooring and walls. The smell of the place originally was truly indescribable. Not the cat urine smell you are dealing with -- more of a unwashed people plus mold plus death plus heaps of damp clothing in every corner smell with a few other overtones. They say that it was the most expensive rehab they have ever done and I am ever so grateful now that the place is owned by a quiet clean old lady.
Brian from Monument
You didn't say there was any carpet. If there is it needs to go.
If there are any window treatments they need to go also.
Then the floor needs shellac or that odor killing paint/sealer.
Needless to say if the area has an A/C unit it needs a new filter at least.
The duct work may need cleaning as well. And probably should be cleaned.
If any of the rooms walls are painted they should be reprimed and painted.
Don't forget the ceiling.
Odors can attach to anything.
Don't forget the doors.
Good luck and don't forget the clothpins for the nose.
My son found some enzyme-based product at a janitorial supply that killed the odor in about a day.
That place had six layers of flooring - carpet and so on - all just soaked with cat pee, so the subfloor had plenty of time to ripen, and whatever he got dealt with it. You might call a janitorial supply company for suggestions.
