ADVERTISE HERE - FREE TRIAL
L shaped shelving Unit for pantry
Mike Foster
I am designing a cabinet/shelf combination for our pantry. I already built cabinets and shelving on the other side of this small room, but now am tackling the other side. I live in VT and had some sugar maples go down on our property a few years ago and had them sliced up into 5/4 boards which have been air drying for 3 years now. This lumber dresses out to a full 4/4 and this what I intend to use for the shelves. I attached a pic of a Sketchup drawing of my plan for the sides I am building. The upper shelving "cabinets" are where my issue is. My wife did not want the shelves have sides that go down to the counter top, and was not enamored with either shelf standards or shelf brackets. My solution is to make units similar to cabinets that will have a "nailing board" (a 1x2 strip of maple attached to the underside of each top shelf that will allow the unit to be screwed into studs). I will also use a 1 x 2 maple ledger which will run the length of all shelves and allow the shelving to be attached to the ledger.
Where my problem lies is in the corner unit with the L shaped shelving. I am not quite sure how to build that due to the movement of the maple. I don't think a mitred shelf will work due to the movement and I think the movement over time will cause the shelves to misalign. My initial thought is to use straight boards the length of the right side, then attach straight boards on the left to the right with a couple of 1" short boards under the shelves that are fixed on the left with slots on the right to accomodate movement. Since the wood should be about at the maximum water content now, I could just butt them up to the left, and as the humidity goes down, a small gap would open. Not a perfect solution, but seems to be the best I can come up with. Wondering if anyone here has some ideas. The shelves will be 12" deep. Thanks in advance for any help.
Below is a pic of the completed part of the pantry. My camera wont get a shot of the whole thing as the room is too small and the lens is not a wide angle.
Re: L shaped shelving Unit for pantry
I believe that I'd use a splined miter joint to turn that corner. The would eliminate your movement issue, I think.
I'd agree with some version of your approach. One of my concerns with this approach, though, is weight. You mentioned it's the pantry; I'm picturing canned goods and other weighty objects. Not sure your little cleats would be up to carrying that weight.
Is it feasible to give up a little bit of the storage and alternate the shelves so that every second one is running right or left out of the corner?
Alternately, can you make a smaller corner unit with the shelves running at 45 degrees to the walls? Not sure how wood movement would work with this approach; just throwing out ideas.
Jesper, Denmark
Jesper, Denmark
Another option would be to install four straight shelving units, and not go into the corner. This would eliminate your problem and only loose the not so useful storage in the corner.
I'm not sure how much real movement you'd be getting with the maple. It would really depend on how the board was cut. If you happened to have something that was close to quarter sawn, you wouldn't have any problems. If you have some boards that approximate quarter sawn - use those.
For pantry shelving - I would really have another weight support other than the single 1x2 board. I'd have another closer to the mid portion of the shelving.
agree
Or the easier to execute, splined butt joint. With stuff on the shelves the joint is not going to show so I would be inclined to use the simpler to make butt joint and let part of it "float" like a bread board end. .
Didn't think of using a spline, but
Mike Foster
it really is the answer to keep the shelves even and still allow movement. I agree with Bill in that a butt joint is easier and won't show when loaded with stuff.
Mike Foster
Yeah, that was one of my concerns as well. I think that I will use fixed shelves with dado's and add another nailer on the middle shelve as you suggest.
Mike Foster
Thanks everyone for the ideas and suggestions. This is a great forum for getting ideas and input.
Another way is to get support from above
Keith Newton
If you have a furrdown, or the ceiling. If you are planning styles in the corner, you can attach the front edge of both through it.
Or, as I just did in the little cabin I'm building, with adjustable pins in the ends of each carcass, and in the back side of the corner styles.
Re: Another way is to get support from above
Mike Foster
Why didn't I think of that? It may be possible. We have exposed post and beam floor joists that may be in the right spots to use a steel wire or the like to get some support. Will have to wait till I get home to evaluate that. Thanks for the idea Keith.
