More on "Chinese Red"
Gary Smyth
I wondered why "Chinese Red" was so popular in ancient times and difficult to locate today. Wikipedia has much about the color but it is now called vermilion. What follows is strongly edited from Wikipedia. Go to that source for a more complete listing.
"Vermilion is a brilliant red or scarlet pigment originally made from the powdered mineral cinnabar, and is also the name of the resulting color. It was widely used in the art and decoration of Ancient Rome, in the illuminated manuscripts of the Middle Ages, in the paintings of the Renaissance, and in the art and lacquerware of China, where it is often called "Chinese Red".
The term cinnabar was used interchangeably with vermilion until the 17th century, when vermilion became the more common name. By the late 18th century 'cinnabar' applied to the unground natural mineral only.
Vermilion is a dense, opaque pigment with a clear, brilliant hue. The pigment was originally made by grinding a powder of cinnabar, the ore which contains mercury. The chemical formula of the pigment is HgS (mercury-II sulfide); like most mercury compounds it is toxic.
Vermilion is not one specific hue; Mercuric sulfides make a range of warm hues – from bright orange-red to a duller bluish-red. Differences in hue are caused by the size of the ground particles of pigment. Larger crystals produce duller and less-orange hue.
Cinnabar pigment was a side-product of the mining of mercury, and mining cinnabar was difficult, expensive and dangerous, because of the toxicity of mercury. The Chinese were probably the first to make a vermilion as early as the 4th century BC. In the early ninth century the process was accurately described by the Arab or Persian alchemist Jabir ibn Hayyan (722–804).
The process described by Jabin ibn Hayyan was fairly simple. Mercury and sulfur were mixed together, forming a black compound of sulphide of mercury, called Aethiopes mineralis. This was then heated in a flask. The compound vaporized, and recondensed in the top of the flask. The flask was broken, the vermilion was taken out, and it was ground. When first created the pigment was almost black, but as it was ground the red color appeared. The longer the color was ground, the finer the color became.
During the 17th century a new method of making the pigment was introduced, known as the 'Dutch' method. Mercury and melted sulfur were mashed to make black mercury sulfide, then heated in retort, producing vapors condensing as a bright, red mercury sulfide. To remove the sulfur these crystals were treated with a strong alkali, washed and finally ground under water to yield the commercial powder form of pigment. The pigment is still made today by essentially the same process.
Vermilion has one important defect; it is liable to darken, or develop a purplish-gray surface sheen.
Genuine vermilion pigment today comes mostly from China; it is a synthetic mercuric sulfide, labeled on paint tubes as PR-106 (Red Pigment 106). The synthetic pigment is of higher quality than vermilion made from ground cinnabar, which has many impurities. The pigment is very toxic, and should be used with great care."
