Winterizing Water System
Tom
Doing this for the first time this year. Guy who used to handle it has moved away. I have a submersible pump; house will freeze solid. General info out there explains about draining the pipes and the tanks. Any information people want to pass on is welcome.
The one part I don't get is the water that would be in the pipes running from the well, through the wall to whatever vaves and so forth are in the house. Recalling from memory the first thing is the pump, then the pressure vessel, then the heater. But as I say, I don't know what happens to any water that may be standing in pipes between the submersible and the basement. Will it just all drain back when the system is opened up, and the pump is turned off? The water system is super simple so I imagine it will drain with a little work, probably will not require a compressor to blow water out, and the one I have is a 1000 miles from here. Just hoping I don't need one to clear the water back to the pump.
Re: Winterizing Water System
Jack Guzman from Maine
When I winterize a home in Maine besides draining the pipes I open all faucets,drain the pump and the pressure tank,and the water heater.I disconnect the pipe that comes from the well at the pump. This is generally black pvc and shouldn't burst if frozen so I don't worry about water in this pipe.Make sure you put rv antifreeze in your drain traps and make sure there is no water in the toilet tank.Also,if the home has forced hot water heat make sure all water is removed from that system. I am not a plumber but I get occasionally asked to perform this function for carpentry clients.---Jack
Bill Turpin in WNC mountains
Plunge most of water out of toilet bowl. Pour antifreeze into bowl to get an approximate 50% solution. Plunge some of solution out of bowl. This is to protect p-trap built into base of toilet. After water is off and drained, turn on the shower diverter to drain the 3' of water between faucet and shower head. If kitchen sink has a hose, after water is off, hold nozzle above your head and turn on. If kitchen sink has a tall riser spout, it will need draining also or temporary removal. Dips in long horizontal runs may not drain even with a compressor pushing it. Air will pass over top half of half filled pipes. Leave ALL drain points open for the entire winter Put window screen wrap around open drains to keep vermin out.
Dan Jechura
Dan Jechura
It's not winter already. Is it?
Dan J. Michigan
Jack and Bill have added good advice. In addition, if there is a shower above a bath tub, try to open the shower after the water is off and drain down the water in the riser between the tub faucet and shower head. Do the best you can, but it will probably be enough to get more than half the water out of long horizontal runs.
Pipes that are filled with water act like hydraulic pistons when they freeze. The water/ice combination expands length-wise in the pipes and if there is no open air in the system, the pressure will increase rapidly until something fails. A fitting will blow off or the pipe will swell until it bursts. This is why the damage is often in some part of the system that actually never froze. A pipe that is less than half full may freeze relatively harmlessly.
Don't ask me how I know about the riser to the shower head freezing.
basil
For several years I had to winterize a house. I would first turn off the water, then open two faucets and stick a nozzle from an air compressor in one and start blowing water out the other one. After awhile when there was room in the hot water heater for air, I'd pressurize the hot water heater tank and go from faucet to faucet or spigot to spigot opening them until most of the water was out of the system. Then I would leave the lowest spigot open and go from point to point blowing any remaining water out of that particular line.
Took awhile but I never had any problems with freezing......and antifreeze in the traps and toilet bowls is good too.
