Some people's balance are worse than others, and an out-of-true stair could precipitate a fall, especially if a person is in socks or slippery-soled shoes. Since you're redoing the stairway, I'd do it plumb and level.
Very much agree. My house in Breckenridge, CO, had a porch stairs when we bought the place that the base settled, making for a tilt outward that I found uncomfortable to shovel the snow off of or to use when it rained. That was one of my first bigger projects around here.
My balance is not what it was, but it was pretty decent earlier in life; I nevertheless slipped going down our slanty porch steps one morning when they were covered in frost, and was in agony for a week after my back met the stairs. Lucky I didn't break anything.
It may be possible to overdo care with stairs, but it's not easy.
My experience with stairs is that they should be level in both directions, front to back and left to right. However, In the real world I have found that deck steps could slope slightly (1/4") toward the rear IF there is drainage. Level steps need adequate drainage. Spaces, cracks whatever, so they do not pond water and ice up. Closed steps like concrete steps also should have drainage either in the form of grooves or an 1/8' Slope to the front.
The risers should be sloped or tucked back under the nosing to keep heals form hitting them on the way down.
The ones I have built with the treads sloping down to the rear about a 1/4" are very pleasant to walk and reassuring. (deck steps)
